Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
Cb will not light up any more
Cb channels will not light up any more and i can not hear or talk to any one
  • Dutyacx May 11, 2010
    Does it look like there is absolutely no power present?
    If so, please check the power lead fuse and reseat the power connector on the backside of the transceiver. There are some fuses/diodes in the first stage where the power enters the transceiver inside. Please check these.
I cant talk
You need at least 8 amp power supply
Sep 06, 2012 | Connex 3300 240-Channels Base CB Radio
When i talk people they can hear me but i cant hear them talk back to me
Turn up your RF gain. If that isn't the issue, then the mic may be damaged. Try a new mic.
Jan 09, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
I just got my new midland CB and installed it on sunday. i can hear people however everytime i try to talk no one responds. The indicator light goes on and the rf meter goes up however i am not getting...
check the SWR. the antenna may not be tuned. Also, you may be hearing skip. If so, they are thousands of miles away, and you don't have enough power to talk to them.
Find some one close to test it.
Nov 03, 2010 | Midland 5001 40-Channels Base CB Radio
How do you properly set the settings for normal use on the Connex 3300
I am guessing that you are talking about getting it to talk on the FCC Citizens band. I am not too firmiliar with connex, but this will work with any radio with expaned channels.
Usually you use a frequency counter to see what frequency you are on when you are playing with the bands.If you do not have a frequency counter you can find the CB this way.
If its in a mobile, or you are not really far from a highway where big rigs travel, you can flip to channel 19 on the channel sellector then flip through the bands checking each time to see if you are on the CB 19. When you start to hear truckers or you get a radio check from a trucker your on CB 19. You can always ask the person, "this is 19 right"?
I recomend geting a frequency counter.
Oct 18, 2009 | Connex 3300 240-Channels Base CB Radio
No sound output
a possible cause would be a broken wire in the microphone cord
May 27, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Midland model 1000
turn squelch all the way off , if you still get nothing you have a bad mic
Nov 21, 2008 | Midland Radio Communications
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
29 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
