Question about ASUS A8N-VM CSM (00610839133826) Motherboard
Plug in my desktop one night and it started smoking, i opened it up and the power supply had a burn on it. i bought a new one and still will not turn on. it did try to power up a few times but no success.it did not say on.
    President:
  • ASUS Master
  • 1,314 Answers
It sounds like your motherboard has also fried. Whatever caused your power supply to burn up caused excessive voltage to go to your motherboard, and it will need to be replaced. There is a possibility that other things connected to your motherboard also fried such as the memory or cpu but you won't be able to determine that unless you replace the motherboard. In my professional opinion, it would be more cost effective to get a new computer at this point. Thanks and please take a moment to rate this solution as fixya, since it answered your question; even if the news isn't very good. Thanks!
Posted on Feb 25, 2009
Why do i have no picture on my philips 42pfl9632d/10 tv. p
Can you hear sound? Is power light on? Where did the smoke come from?
Jan 10, 2015 | Philips Televison & Video
I was burning a movie and my computer flash off than on than shut off.. it spelled like electrical wire burning. now it will not even turn on
Sounds like the power supply died. This is where your power cord plugs into the pc. It is a metal box inside the pc. Smell the back of the pc, at the fan opening closest to the power cord. If it smells burnt there, then you need a new power supply.
Hope this helps!
Joe
Apr 08, 2012 | Sony Computers & Internet
I have a T6212 where it had been unplugged for a month or two. As i was hooking it back up, I plugged the power cord in first where, as soon as contact was made the unit sparked and smoked. The unit...
Hi:
Let's start with the smoke first; probably the pc received an overload and the power unit burned. No big deal. You can buy a PC power unit from 30 bucks all the way to the hundreds. It comes with instruction. Just open PC's main cover disconnect all cables and recycle the burned unit. Here's the link from amazon for a cheap one. http://www.amazon.com/Antec-BP350-Basiq-Power-Supply/dp/B000H9J3ZC
Now if you want to take the hard drive off, also you can do that, disconnect all cables from the hard drive and purchase the cable kit to transfer all data to another computer. Here's the link for the cables: http://www.amazon.com/gp/product/B0018MCGVU
Good Luck!
Sep 07, 2011 | E-Machines T6212 PC Desktop
Hi, my GX-260 locked. Now it will not boot up and no video. I'm thinking motherboard or power supply?
Please pay attention to beeps when system starts. If any, check the table in the link.
Then check the diagnostic leds on the back of the unit (labelled A, B, C and D).
Check the meaning in the link.
If you press the on switch and the fan in the power supply starts rolling then it could be motherboard.
Also notice if the power supply has a smoke or burning smell.
Here is the diagnostic link:
http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm
Feb 03, 2011 | Dell OptiPlex GX260 PC Desktop
My 110v PC was plugged in 220v
Since something smoked I would look for physical damage on the motherboard and other cards. Make sure your video chip isn't visibly fried. If the physical damage is limited to the power supply I would definitely change it out, because it could damage other parts of your system and that's not a chance you want to take. Also, if the video is fried just get a video card and run with it.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Dell dimension starts up then shuts down
power supply shot
can get power supply from microcenter
http://www.microcenter.com/single_product_results.phtml?product_id=0293459
or take your out REMEMBER where plugs go and buy a new one cheap
Jun 01, 2009 | Dell Dimension 3000 PC Desktop
Computer won't stay booted.Replaced power supply a few months ago when I had this problem and it just started again
Sounds like the power supply is being suffocated with pet hair/smoke and it is overheating. A new power supply would have solved this issue until it eventually sucked in enough hair/smoke. If so, I would recommend canned air to clean out the insides on a regular basis.
Apr 13, 2009 | HP Pavilion a1630n PC Desktop
Power supply not working?
To see if power supply works
unplug the psu from the motherboard and drives
then plug the power cord into psu and wall
the fan should come on letting you know that it works.
you can also get a multimeter and check each individual connector on the 20/24 pin connector to motherboard.
check the psu docs for the correct voltages to each pin
If you smelled smoke then chances are that something may have gotten toasted.
remove all expansion cards and try to turn on computer if nothing happens then the motherboard may have gotten toasted.
Check the motherboard and expansion cards along with memory for shorts and burn spots.
A+ Technician
Apr 02, 2009 | HP HEC HP485D 485W ORION HP485D ATX 12V...
Plug in 220 v power line, it burns and smokes. Can data be saved?
Is the power supply internal or external? If external, then just find a similiar or identical unit. If internal, then you could try removing the hard drive and installing it temporarily in a desktop system. Obviously, interfaces must match (SATA, IDE). You could then see if it is accessible, and get any files.
Aug 18, 2008 | Buffalo Technology DriveStation HD-HC500U2...
ASUS A8N-VM CSM (00610839133826) Motherboard Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
