Question about Clarion DB285USB Car CD/ MP3 Player
Installed and no sound or nothing
Hooked all the wiering by instructions and when turned on..... just got i guess you will call it a error message....... "AMP GRD" across screen... caint figure out what this means..... in need of help
    Problem Solver:
  • 9 Answers
Im guessing you have an amplifier if not check the cd player ground " AMP GRD" means amp ground is faulty. In the event that you do have an amplifier check that ground wire as it's most likely the problem.
Posted on Feb 25, 2009
Radio works but no sound
Its the wiering to the speakers. Or if u have it hooked up to an amp it might nkt be hooked up right.
May 03, 2013 | Toyota Tundra Cars & Trucks
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Im trying to hook up some roof marker lamps so they come on when i turn my running lights on
just run it threw the fuse box with the running lights and be sure to ground it.
Jan 25, 2010 | 1999 Chevrolet S-10 Pickup
I turned on the DLPtv it made a weird sound and nothing happened.
Sounds like the High-voltage went out on the TV, probably have to replace TV
Aug 22, 2009 | RCA TruFlat 27F520T 27" TV
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
99 740il will not crank
if it was starting up fine and stopped cranking all the lights light up on the dash but just dosent start look under the carpet on the passenger side the is another fuse box panel there if there hasnt been any water in the car it can rust it out and blow fuses and cause other electrical problems that what happened to us we are looking for this part right now my husband probe the wires and everything works
Mar 16, 2009 | 1999 BMW 7 Series
Eclipse DA7122 amp
Did you hook up your other amp again to make sure nothing happened in your wiring? *curious*
Apr 09, 2008 | Car Audio & Video
Operators Error - won't respond to anything
i have the same problem and im clueless as how to fix it :(
Dec 19, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Clarion DB285USB Car CD/ MP3 Player Logo
746 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
