Question about Kaito KA1103 SW/FM/AM Radio
New KA1103 - no power
Installed batteries and plugged into outlet...No backlight, no power of any kind
  • 3 Answers
Have you depressed the 'Reset' button which is in the small hole next to the 'On-Off' button. Do that with a common pin or the end of a paper clip.
Posted on May 21, 2009
Blacked out. won't come on. no red "on" light. Outlet tested hot. Recently started turning off and re-starting.
I assume you tested the outlet by plugging in another device. Sounds to me like the internal power supply may be bad. This is better than the backlight going bad as a power supply is usually much cheaper to get a hold of. I'm not sure of your level of expertise, but please be aware that there is high voltage inside your unit. I recommend having a trained professional do this as the risk of shock is quite high. I would tell this professional to check the power into the power supply section and out of the power supply section. if it is bad, order a whole new power supply board. Repairing these is quite difficult, even in a lab. shopjimmy.com is a good source for tv parts.
Mar 31, 2016 | Televison & Video
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
Hi There, I have a Belling 5 burner gas hob. Just cleaned it down and now the igniter keeps on sparking as if i am pushing down on one of the knobs to try and light it, but i'm not touching anything. ...
your unit is batery or power supply operated? if batery supply depend on the model or brand were exactly the battery but mostly at the back of the unit,but if power supply pls can you check if the power plug is in outlet.or your outlet try to use any kind of appliances to check if der a power supply,check also the plug of your range if have a fuse inside the plug?to make is sure replace to a new one.
Dec 17, 2010 | Belling Solitaire G747 Gas Kitchen Range
My PC will only turn on for 1 second and then shuts down. I've disconnected everything such as fans, hard drives. I put on a new power supply box and CMOS battery. Can the switch in the front be faulty?
Is your computer plugged-in to a power bar?
If yes kindly disconnect it from there, then try to plug-in your computer's power cable directly to a wall outlet, you can also try other wall outlets, if this one will still not work, there might be a problem already with the motherboard.
I also encountered this problem before.
Mar 01, 2010 | Gateway GM5084 PC Desktop
Kaito KA1103 Replacement AC Adapter to work in Australia
you can get on your electronics shop store near you, and antena also.
Jan 03, 2010 | Kaito KA1103 SW/FM/AM Radio
Don't know how to recharge the batteries while they are installed in the radio.
Had to repeat depressing the 'Reset' button at least 4 times before the set would come on. This may have been due to fact that the unit had not been used in almost a year. Also found that the set was shutting down when the status of the battery charge was checked. This was most likely caused by two defective batteries. Put in a new set of 4 rechargeable batteries and unit is now working fine.
May 19, 2009 | Kaito KA1103 SW/FM/AM Radio
Battery Get Discharged within few Minutes even after Full Charge
I have the same problem, and for now an external charger is the best solution. Also try resetting 4 times. I also got a new power supply, but problem persist. Good luck!!!
jav
Nov 19, 2008 | Kaito KA1103 SW/FM/AM Radio
Gateway MX6920 won't power on.
You Need To Replace The DC Jack In The Laptop...
It Is The Jack THat Your AC Adapter Plugs into....
The Jack Needs to Be Unsoldered/Removed/Cleaned And A New Jack Installed..
I Wouldn't Bring It To That Same Repair Shop To Do THe DC Jack Repair FYI...... ouch!!!
http://www.ifixlaptops.com
Nov 16, 2008 | Gateway MX6920 Notebook
Kaito 1103 Shortwave Radio
I dont have this radio but I remember reading that you push the volume button then turn the tuning knob to change the volume.
Sep 23, 2008 | Kaito KA1103 SW/FM/AM Radio
Battery Depleted
Are you able to run the laptop with no battery installed but the power cable plugged in? If not, there's a good chance your power jack on your laptop has broken (or almost broken) and will need to be replaced or the power adapter isn't working.
If it does run, your battery is probably bad and can't take any charge. It will need to be replaced.
Apr 10, 2008 | HP Pavilion dv1000 Notebook
Kaito KA1103 SW/FM/AM Radio Logo
127 people viewed this question
Top Kaito Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
