Question about SonicWALL TotalSecure 3G (TZ190) (01-SSC-6088) Firewall
Can not connect to sonicwall tz190
When I reset the sonicwall and I can not get to 192.168.168.168 any help? on the setuptool show 192.168.168.168 but when I type 192.168.168.168 I can't connected
Some times you have to manually assign an IP within the same range to your PC 192.168.168.55 than go to 192.168.168.168 in your web browser, be sure to be connected to a LAN port and it should work.
Posted on Jan 12, 2010
    Problem Solver:
  • 9 Answers
Mani is correct. But also check the cable type is Cross Over Cable. and check the ip address in your system. If not assigned, enable DHCP in your system.
Thanks,
Sriram.S,
Chennai - 4.
Posted on May 12, 2009
    Problem Solver:
  • 5 Answers
Hi
In factory default,DHCP is enabled just connect any pc and see whether you are getting any ip.
Regards,
Mani.S
Posted on Mar 13, 2009
How to block torrent download in sonicwall tz190
BitTorrent is a torrent downloading client used to download
music, video and game files for free.
BitTorrent can really eat up bandwidth, which can be mighty
frustrating, especially if you're sharing a computer and an Internet connection
with someone who's using BitTorrent.
If he's not willing to stop using BitTorrent, there are a
few steps you can take to block this demanding program.
Switch your Internet service to an Internet service provider (ISP) that is
hostile to BitTorrent. RCN, for example, is known to block BitTorrent traffic.
Try blocking all ports from 6881 to 6999 on your system.
You must first add a port before you can block it. Click
"Control Panel" and then "Network and Internet
Connections."
Click "Firewall Settings," and select the
"Exceptions" tab.
Click the "Add Ports" button. Enter the port
number you want to block, and click "OK" to save your changes.
Navigate to the "General" tab in the "Windows
Firewall" section, and remove the check mark from the port you just
created.
That port is now blocked and cannot be used by BitTorrent.
Unfortunately, performing this procedure 118 times is
somewhat time consuming, but it is one of the few ways known to block
BitTorrent.
If someone is using BitTorrent on your computer, don't
allow him access to it.
If he's using BitTorrent on his own computer, you may have
to buy your own machine to avoid conflict.
If the Internet is slow on your computer because
he's downloading via BitTorrent on his own machine, consider using a public
Wi-Fi point such as a library or coffeehouse.
Nov 11, 2013 | SonicWALL TZ170 (01-ssc-5740) Firewall
I am using sonic TZ190 Firewall and unable to access yahoo.com mails the page is not displaying contents
I have determined that the problem is actually 69.147.112.160, which seems to be a login server at yahoo. I say this because you can actually browse the Yahoo website, and go to new.mail.yahoo.com without any problems. However, trying to connect to mail.yahoo.com or login.yahoo.com returns the above error.
Jul 01, 2010 | SonicWALL Content Filter List (01SSC2733)
I just purchased a new modem and the sonic wall tz190 will not retrieve new ip address...
1. Check the manufacturer's web site for update this could be the issue
Most new router modem off the shelf have not been update by the manufacturer due to delay engineer changes and may only become available after shipment to the retail stores.
Here is there site if you can connect through a friend or relative connection and download the updates for your unit.
the update also may be able to go onto a 4gb flashdrive.
http://www.sonicwall.com/us/support/3141.html
Mar 25, 2010 | SonicWALL TZ170 (01-ssc-5740) Firewall
Cofiguring sonicwall TZ190 to block all trojans and viruses
The"svchost.exe" is a normall windows system files.
It does not cause any harm to your pc.
It's only a running process.
Regards
Uttam
Feb 19, 2010 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
I need to be able to ping the SonicWall TZ190 wan ip from the Internet for tracert puposes. There is no ping response to that IP address. The manual says. Click Objects, and then Services. Verify that...
Saibrains is correct unless your firmware is of earlier version. you might have to upgrade your firmware. Also you can not use a port #
No ports required for Ping as it uses icmp packets
It needs to allow icmp 'echo-request' (type 8) packets out and icmp 'echo-reply' (type 0) packets in
to allow ping request. On earlier versions of the sonicwall firmware it only absorbed Ping request as to stop hackers from ping attacking pass the firewall.
check the manufactures website for your model and see if they have newwer firmware.
The GUI should have a place where you can set it up
Apr 09, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Sonicwall site2site vpn issues
please select nebios option in hq site tz190 firewall.
Apr 07, 2009 | Sonicwall TZ 170 NFR (01-ssc-5564)...
SonicWall 5060 will not reset to factory default
hi,
there is notch on sonicwall to reset it.
Mar 07, 2009 | SonicWALL Pro 5060F Firewall
I have hp scanner 2400 iwant instal it linux 5.2
insert the CD, and click on next, next and next
when it asks for agreement select accept
Jan 02, 2009 | SonicWALL TotalSecure 3G (TZ190)...
Help with installing a sonicwall soho tzw no software.
Hello dlewis2900, What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
Sep 03, 2007 | SonicWALL TELE2 Firewall
SonicWALL TotalSecure 3G (TZ190) (01-SSC-6088) Firewall Logo
3,188 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Raymond Ramirez
Raymond Ramirez
Alun Cox
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
