Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Kenmore 22 Porcelain Plus Fridge
Ice maker stopped working. Everything looks good. Tube is wide open. Module looks ok.
vanni7
  • 163 Answers
SOURCE: no water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Posted on Jan 04, 2009
  • 1314 Answers
SOURCE: Kenmore Side by Side Fridge - Ice maker/water dispenser
we got to chat about this so hold my rating till we are don how is your water hooked up house valve or self pericing saddle valve what kind of pipes do you have when you push the door dispensor do you hear any sound have you checked your filter
Posted on Mar 31, 2008
SOURCE: Kenmore 20 porcelain plus refrigerator
5' 6" Tall
32 1/2" Wide
28" Deep
I bought that old fridge at a garage sale for cheap. It's been enjoyed for me for just over a year. :)
Posted on Aug 21, 2008
  • 53 Answers
SOURCE: Fans in refer/freezer run continuously
it suppose to run so long the compressor is running it goes into defrost every 8 or 10 hours or it shuts off if it reaches temp but if you can hear the compressor running and the evap fan aint running somethings definitly wrong
Posted on Nov 05, 2009
  • 1218 Answers
SOURCE: Kenmore 19 Porcelain Plus (26 years old) with ice
Good day,
In that era they made 2 types of ice makers. If yours is the type that makes half moon ice cubes then it can be repaired.
You have to remove the ice maker. 3 screws and a wire plug. unsnap the front plastic cover. Remove the large plastic gear. You will see 4 screws one on each corner. Remove the screws and lift the plate away from the body. The ice maker must be pointed up.
You will see a small microswitch, on the right side. It has failed.
The switch is universal and most appliance houses will have a replacement.
I have made it sound simple, but it can posse problems since there are a lot of alignment issues in reassembling it. If your handy at this sort of thing you'll be O.K.
If the icemaker is the style that has a large plastic tray that the cubes are formed in, then that is another issue, and should be handled by someone who knows the icemaker.
Some appliance parts houses have someone who can perform these repairs, but unfortunately, the second style when removed, will shut the machine down completely.
Thanks for using FixYa
Posted on Dec 18, 2009
Testimonial: "This guy knows his stuff!!!!!"
My Kenmore Elite Trio Fridge is leaking water from under the front of the machine. It is not the water connection. Do you know what the problem might be?
Your defrost drain tube is probably clogged with ice or something. Defrost your refrigerator (put towels around to soak up any excess water), then after it's defrosted, take off the back, lower panel and look for a 1 inch diameter tube coming down from your refrigerator. Remove it and clear out any blockages and then re-assemble everything.
Oct 15, 2014 | Kenmore Refrigerators
I have a side by side Kenmore fridge, model# 106.53532300. The ice maker has stopped making ice all of a sudden. Everything else works fine.
Ice makers do go bad and it is inevitable. Check the ice maker connection and make sure that all is in order. If all seems okay and the ice maker does not work, replace it.
Dec 19, 2010 | Kenmore Refrigerators
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Component Ice Maker, What Else Could It Be...
remove ice maker maker sure is clear and also check the fill tube that supplies water to mold they sometimes have a plug of ice and no wtr comes out to mold that is if you already sure that there is wtr being supplied ok to unit
Oct 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
5' 6" Tall
32 1/2" Wide
28" Deep
Jul 17, 2008 | Kenmore 64802 Top Freezer Refrigerator
I have the same problem with my whirlpool every once in a while, and I found out that if I run a hot air dryer at the back of the fridge where the water tube comes in and along the ice maker it loosens everything up. I think that for some reason the water freezes in the tube somehow and prevents a full cycle. When I am using the hair dryer i can feel the frozen ice come sliding out of the tube. Also I know when I am getting close to thawing everything out when the ice maker runs through a cycle while I am blowing the hot air on it. Good luck.
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Whirlpool icemaker
I changed the filter and it stopped making ice. I finally discovered that the rubber fill spout had frozen somehow. I heated the tube with my wife's hair dryer and the top of the fridge just above the tube. A pencil sized chunk of ice fell out of the tube and it started making ice again.
Jan 16, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
699 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
