Question about Kenmore 78673 Gas Kitchen Range
Gas range oven doesnt work but i see the orange glow from igniter help me?
  • 57 Answers
It is likely that the lowe igniter needs to be replaced.
Posted on Sep 22, 2009
The gas in my oven doesnt work
When you turn the oven on is there an orange glow near the burner?. If so, the gas valve for the burner is bad. If not , then the igniter isn't working
Jun 17, 2015 | Kitchen Ranges
Gas oven doesnt work
Hello there:
Gas oven won't work, Ignitor is glowing Everything in the circuit must have continuity for the oven to fire up. What if the ignitor glows but the oven will still not come on? If the ignitor is glowing that would mean you have a circuit. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. The only way the gas oven valve would be bad is if it is open and has no continuity. That goes for the control as well. Check out this simple diagram of how a basic gas range operates. glowbar.jpg oven ignitor An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas: gas-ignitor-circuit.anim.5. Click on image to see it in motion
Apr 27, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Gas oven not lighting
Hi the problem here is the igniter. Take the floor of the oven out and then the flame spreader. The igniter will be located at the back of the burner. Set the oven for 350, if the igniter does not light then test it with an ohms meter it should read continuity. If it reads open you should replace it. If the igniter does glow it still could be bad, the igniter should glow bright yellow to the point you can't look at it. If the igniter glows orange/yellow it is bad you will need to replace it. If you have any other questions please feel free to comment. Mike
Feb 13, 2010 | GE JGBS20 Gas Kitchen Range
My gas stove model # 790.77471792 does not heat up past 100 deg. The broiler and the the top burners light. can someone tell me what the problem could be? i did notice that when I turned on the pre heat I...
The orange glow you see is coming from the oven igniter. The igniter needs to glow white hot in order to light. You need to replace the oven igniter. Hope this helps.
Nov 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
When i turn on my gas oven sometimes it lights but most times it does not.
It is likley that the ignitor is failing and need to be replaced. If you watch thru the window when turning on, you'll see a bright orange glow as the oven ignitor heats up to ignite the gas.
Even though the ignitor will still glow bright orange, it could be getting weak and might have to be replaced.
The other thing that might need to be looked at is the flame/temp sensor. If that isn't working correctly, it's possible that you aren't getting any gas consistently to the oven so the ignitor can ignite the gas. The sensor has to heat up in order for the gas valve to open, allowing gas to flow into the oven and thus get ignited for a flame to occur.
Without the model number, I can't provide you with the replacement parts for your range. However, you can go to and enter in your exact model number and get a list and price for the parts I've described. Just enter in your model number in the "find a part" search and you'll get all drawings for your range. If your model is very old, you might have to call them in order to get the part numbers and pricing.
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | Amana Kitchen Ranges
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
Nov 19, 2007 | GE JGRP17 Gas Single Oven
Kenmore 78673 Gas Kitchen Range Logo
61 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
