Question about Dell Dimension E520 PC Desktop
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel® CoreTM 2 Duo Processor, what do you think? It's a great computer, I just want to have peak performance.
  • Anonymous Feb 25, 2009
    pc hang up
    I do shut down my computer properly every day, I AM an IT guy, I had already increased the file size settings, not sure what I changed it to, but please tell me, what it should be, or if you have any suggestions on what it should be. So you don't think a new processor will change this?
  • 203 Answers
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Posted on Feb 25, 2009
How do I find working XP video card drivers for a Gateway TA7/ Viper-SR laptop/tablet?
are you sure about the driver/chip? You may need to double check - was this an upgrade/ change of OS from a Vista machine? Or could it be direct x? read below.... otherwise I have no idea sorry ATI Mobility Radeon HD 2300 csm_ati_radeon_chip_05_e8206cf22f.jpgThe Mobility Radeon HD 2300 graphic card for laptops is the successor of the X1300 and supports only DirectX9 (according the informations of the AMD homepage). The performance shall be somewhat above the X1300 and therefore present average or worse game performance. AMD / ATI tells that the relation of performance/Watt has been improved. Rumours tell that the chip is only a renamed X1300 / X1350 video chip.
A difference to the X2300 are the amplified video options (UVD).
The HD 2300 graphic processor is certified for Windows Vista and supports the Windows Aero Glass Interface.
Manufacturer ATI Mobility Radeon HD 2000 Series Mobility Radeon HD 2300 4/2 cores @ 480 MHz 128 Bit @ 400 MHz Codename M71 Architecture RV5xx Pipelines 4 / 2 Pixel- / Vertexshader Core Speed * 480 MHz Memory Speed * 400 MHz Memory Bus Width 128 Bit Memory Type DDR1/DDR2/GDDR3 Shared Memory no
HyperMemory wird unterst?tzt DirectX DirectX 9c, Shader 3.0 Transistors 115 Million technology 90 nm Features 90nm manufacturing process, PCI Express X16 Interrace, PowerPlay 6.0, Avivo Video architecture (MPEG-2, MPEG-4, DivX, WMV9, VC-1 acceleration), 64-bit floating point HDR, Ultra-Threaded Shader Engine, OpenGL 2.0 Date of Announcement Link to Manufacturer Page http://ati.amd.com/products/MobilityRade...
Nov 25, 2014 | Gateway Ta7 E-295 Laptop Tablet, Core 2...
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
How do I update driver for ati radeon x1300 pro graphic card?
Hello there,
You can try to download the updated driver from ATI's website. Make sure that you are downloading the correct version for your operating system.
http://support.amd.com/us/gpudownload/Pages/index.aspx
Dec 26, 2010 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Jun 15, 2010 | ATI RADEON 9550 Graphic Card
Im running an ATI Radeon x1300/1550 pro graphics card(256m) .. on OS win XP (sp2) all up to date drivers and DirectX9 but wen i try to play any on line game i just get a white screen i get sound but no...
- does it work properly when u disable the online game feature (play the same game without just on your PC or in LAN-session)
-goto network connections and disable every connection available besides the one u use for internet access
(as u can wire up video cameras
to the card via the 1394/port, this port may have been recognized as network adaptor in windows, this might cause IRQ problems and as u do not use it, it is wise to disable it)
retry now the online game / if stil the prob, came back to fixya!
good luck
Aug 08, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
I need help :)
This is not really my area of expertise. I think you would be better off asking Ekse. He would be able to guide you better in this regard.
Cheers!
ID
Nov 07, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
S video out
To my thinking, your concern would largely be dependent on the Screen Resolution setting of the PC. It may be that the screen resolution be initially lowered down to the lowest possible.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Driver for my video card
Here is where you can get your driver. It's for WinXP but you can get the one for Vista if you need. Didn't know if you wanted the software suite that goes along with it but that can be downloaded from same page as well. Enjoy! If this fixes your prob, please rate me a big 4 fix ya. Thanks.
Mar 17, 2008 | Power Color PowerColor RADEON X1300 256MB...
Dell Dimension E520 PC Desktop Logo
99 people viewed this question
Alun Cox
