Question about HP Photosmart C6180 All-In-One InkJet Printer
HAVE HP C6180 ON VISTA HOME PREMIUM. THE PRINTER STATUS IS OFFLINE AND DOESN'T SEEM TO BE ABLE TO BE SIMPLY SWITCHED OVER TO ONLINE. IT CAN BE SEEN ON MY WIRELESS NETWORK BY THE LAPTOP.I JUST CAN'T DO ANYTHING TO GET IT BACK ON LINE?
    Guru:
  • 224 Answers
Insert the hp printer installation cd into the cd drive and exit out of the autorun option then double click the computer icon to open the computer featuers and right click on the cd drive and select open then go into the folder called "util" inside that go into the folder called "ccc"
now inside ccc look for a file called uninstallation l1 and double click on that (this will uninstall your incorrect the drivers for this printer).
once that is done restart the computer and re-insert the installation printer cd and open computer and double left click on the cd drive and in the splash screen select install or add a device whichever you get complete the installation and your printer will start printing again(keep in mind that before clicking on install or add a device click on start and in the start search bar type "services.msc" click on ok and in the new window look for hp network device and hp cue and double click on them and make sure in the drop down list only automatic shows and nothing else). Happy printing
Posted on Jun 23, 2009
    Scholar:
  • 169 Answers
Well it s a issues with the ip address on the printer and the computer.Both of them are not the same.You need to delete the printer icon and inser the cd that came with the printer and then try add a device .The printer drivers would be reinstalled and it should be ready to print and scan.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
Dec 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Vista Home won't print
are drivers up-to-date? it's in most cases driver fault offline status means printer is not communicating with pc not that it needs to be checked use printer offline. are cables tested by cable tester? that cable seems ok and it's plugged in doesn't mean it's ok inside
Sep 22, 2009 | Microsoft Windows Vista Home Basic Edition
Photosmart c6180 printer status offline
IF you have more than one printer set up on your system take all the others off except this one if you are able to without disrupting your home printing flow for others.
Another suggestion would be to download the newest drivers if you have not already; I found the site below with the drivers for this printer at:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=1153494&
Hope this helps.
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
My HP C6180 stopped printing photos. I am using
buddy download service pack 2
:it will fix the problem
Jul 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6180 All-in-one Offline mode
Go to www.hp.com. let the PRINTERS section auto-detect your printer and download the drivers automatically.
Jun 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Problems printing on HP 1220c using vista
1.make sure printer is in ready condition(lamp indicator not blinking) and conected.if blinking thers problems with printer ,catridge or something
2.contrlol panel>printer chek status of printer.if 'offline' its not properly conected.if 'ready' then>
3.download hp diagnostic tool from hp website and run it.it will detect the problem and follow the instruction.if not work>
4.uninstal driver and printer,reinstal it.if not work>
5.try on another comptr.
Mar 04, 2009 | HP DeskJet 1220c InkJet Printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer Offline
here are the steps to do:
- click start icon
- goto control panel
- under control panel click printers folder
- then under printers folder there is an icon for photosmart c6100 printer - right click that icon then set as a default printer
- then right click the icon again and select use printer online
- after that you can see you printer has a checkmark and the status is ready.
Jul 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 2575 printer is offline - won't print
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
