Question about Kenmore Elite 45986 Front Load Washer
Washing machine shut off valve leaks from on off lever.
  • 15,935 Answers
It appears your valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How to set my wshing machine initialy?
If the laundry area already has all the set up, all you have to de is hook the washer's
Diagram of a washing machine to help you install a washing machine
drain hose over the sink's edge. If there is no sink nearby, the washer will need to drain into a standpipe. A drain pipe is basically a pipe with a diameter of 2 inches with a built-in trap that taps into the nearest drainpipe. The top of the standpipe should be between 18 to 42 inches above the trap. The trap should be about 6 to 20 inches above the floor. Standpipes are readily available with built-in traps or can be assembled using standard drainpipe and elbow fittings.
To prevent any unexpected and unwanted flood because of any leakage or bust f the hose pipe, you can use a single-lever valve in place of conventional washing machine shutoff valves. You can simply flip the liver to shut off when the washing machine is not in use.
  1. Screw the washing machine's water supply hoses onto the connections at the back of the washing machine. If the hoses are marked, orient them to hot and cold according to the markings.
  2. Connect the washing machine supply hoses to the right valves. Adjust the level of the machine.
  3. Put the drain hose into the standpipe or the laundry sink. Turn on the water supply valves, and check for leaks.
May 17, 2011 | Washing Machines
Tip
How to fix a Washing Machine if it is leaking
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is oversudsing, which can cause it to overflow. Reduce suds by pouring in 1/2 cup white vinegar in 1 quart water. Then switch to either less detergent or a low-sudsing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repairperson.
on Sep 03, 2010 | Washing Machines
After the wash cycle is over im finding water inside the machine. it seems to be filling up after the clothes are taken out.
Let's do some trouble shooting to eliminate various possibilities:
Can you find the shut off valves behind the Washing Machine?
Next time, when you are done with a load of wash, and won't be using it for awhile, SHUT OFF both the Hot and the Cold water valves (See the long black hoses going from the valves , into the machine?
(I suggest taping a small sign on the Washing Machine lid-- So you will remember to open the valves before you do your next load of wash!-- A Washing machine has a hard time washing, with the water valves shut off! :-) )
Did that stop the water in the machine bowl?
If that worked-- Then next time-- just shut off the HOT water valve-- see if it still stops the water in the bottom---
Then try the Cold Water valve-- Manually shutting off one valve each time..)
Now you may have learned WHICH of the Solenoid valve in the machine is leaking...
Do you want to dig into trying to fix our replace the valve?
Let us know-- and we can go deeper into the repair.
Mack B
Jan 26, 2011 | Washing Machines
Water is leaking from the injector hose is the injector need changing or could it be plugged?
If I got the issue correct the washing machine is leaking specially from the injectore.
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, Be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
2) Determine whether the machine is oversudsing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-sudsing variety.
3) the machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repair person.
Thank You for contacting fixya.com
Oct 12, 2009 | Kenmore 22422 Top Load Washer
Water is pooling in the front of the top loading washing machine
If I got the issue correct the washing machine is leaking specially from the in front of your top loading washing machine.
2) Determine whether the machine is overwashing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-washing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repair person.
Oct 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine is leaking while filling and before rinse
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Leaks behind the ciment cast
Oct 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It is leaking under the washer tub
Oct 12, 2009 | Washing Machines
Creda simplicity 1000 leaks
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. Note: To prevent serious flood damage, which can occur if washing machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as show in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses, and drain them into a bucket after disconnecting them).
2) Determine whether the machine is oversudsing during wash loads, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup of white vinegar in 1 quart water into the washer. Then switch to less detergent or a low-sudsing variety.
Thanks for your question.
Jan 03, 2009 | Washing Machines
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
97 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
