Question about Admiral AW22 Top Load Washer
Very loud bearing noise in spin cycle on five year old admiral washer
    Genius:
  • 1,075 Answers
There are just two possible causes 1;; is the main motor bearings.2;;the main carrier bearings in which your drum runs.you might find it cheaper to replace the whole washer.hope this helps.adrian
Posted on Feb 25, 2009
I have a admiral washing maching, model LNC6766B71, it is top load. It makes a load noise in spin mode.
if noise is constant maybe bearings? Is the load even? Not totally familiar with item but the I think the two possibilities above are worth considering. Do an spin on empty. NOISE??? I would guess bearings.
Jan 02, 2016 | Admiral Washing Machines
My washer is very loud when it is in the spin cycle.
if the machine is more than five years old or it gets a lot of use it sounds like the drum bearings are starting to wear. If it sounds like a jet taking off when it begins to spin then thats your problem. Basically bearings have seals which over time and use will eventually allow water in and the bearings will start to wear. Now is the time to get the bearings done before they seize. It can be a laborious and expensive job
May 24, 2010 | Kenmore 43042 Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Admiral capacity plus too loud during spin cycle. This is not a normal sound EXTREMELY LOUD!! What could cause this??
If its older then 10 years then its probably the tub bearing and seal.If you can do this tilt the machine back look under the bottom and turn the belt by hand and if you can isolate if the noise is not the water pump bearing. rate this !!
Nov 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
Noisy spin cycle
The spin bearing is the culprit. Water works down through the tub seal onto the bearing.
Jan 15, 2008 | Maytag MAV8557 Top Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
318 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
