Viking washer problem is it just stopped spinning
  • Anonymous May 17, 2009
    I have an Eaton Viking 8 two speed, heavy duty cloths washer. It can no longer spin fast enough to remove water from the cloths. It spins slowly and there is a smell of burnt rubber.
    I imagine this means I need to change a drive belt. Any directions on how to do this?
  • fixer444 May 11, 2010
    Clean out your filter................
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
I have an eaton viking washing machine, the agitator has quit working but it still goes thru the time cycles. door switch still good but the motor has a humm but does not spin. trans still turn by han
You need to drain it, A wet and dry vac works good for this. Then unhook it and unplug it and lay it down so that you can see the bottom. There is a motor there and you need to make sure that the wires that connect ot it are ok. If the machine has been run and it was off balance it might have broken the wire that makes the motor spin.
Oct 15, 2012 | Viking Washing Machines
Eaton viking dryer model ED214W449 .Loud hum when you try to star
My Eaton Viking Dryer Model # ED214W449 was running, I heard a loud bang and realized the drum had stopped turning and won't restart. Is this a drum belt issue? Is it hard to repair myself. Where can I get the part for this. Thank you.
Mar 24, 2009 | Dryers
Washer stops during spin cycle
i just relaced my door switch to my washer and it fixed my problem.my washer was doing the same thing as yours
Mar 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag neptune tl washer
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
Apr 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
355 people viewed this question
Top Washing Machines Experts
