Question about Clarion VRX935VD Car DVD Player
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio instructions are easy
  • 41 Answers
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Posted on Feb 24, 2009
Tail light wiring color code 2005 dodge cgrand caravan
Sounds like you have the wrong part.Did you buy it new or is it used?
Aug 02, 2015 | 2005 Dodge Caravan
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
I need the wiring diagram for a pioneer avic-n2! i need to know which colors do what!
Pioneers wiring is easy. Red is ignition-Yellow is battery-Black is ground-Blue is remote for amp or antenna-Orange is illumination-Speaker wires are usually grey, grey w/blk stripe-white, white w/white stripe-green, green w/blk stripe-purple, purple w/blk stripe. Green and purple is rear, white and grey is front
Sep 18, 2010 | Pioneer AVIC-N2 Car DVD Player
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
I need a factory radio wiring diagram for a 2006 chevy 1 ton just a am/fm cd player
1989-1990 And Newer
A B C D E F G H I J
K L M N
F Not Used
Smaller sized
Feb 01, 2010 | 2004 Mazda 3
DEH-1330R CAR CD PLAYER WHICH IS POWER WHICH IS SPEAKERS
Wiring is pretty much standard for all 4 channel radios. red is switched, yellow is your memory (constant power), black ground, purple/purple-blk, white/white-blk, grey/-grey-blk and green/green-blk all speakers the solids are positive and blk stripes are negatives. orange is illumination, blue maybe 2 are amp switched for power on/of and the other power anteanna. Its easiest to get a wiring harness for your car it will connect color to color and then plug directly into your factory harness with no splicing of the wires so when you trade in/sell your car the factory radio goes back in with ease.
Aug 06, 2009 | Pioneer Car Audio & Video
Can i get wiring diagram of sterio for Acura Rsx 2004?
Generally there are two types of wires , power , and sound. The power wires will usually be black , red , and yellow or orange. Might also have a blue one. Black is ground , Red is constant power , yellow or orange is accessory power ( only energized when key turned on) .
If you have a blue wire , it sends out power when stereo is on , to power an electric antenna or turn on an external amp. All other wires will be in colored pairs. For example Green and Green with a black stripe , Grey , and Grey with a black stripe , purple and purple with a black stripe.......These are all speaker wires , the solid color one is the + and the one with the stripe is the - , EG: Grey might be right front + , and Grey with black stripe would be right front -
May 03, 2009 | 2003 Acura RSX
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Clarion VRX935VD Car DVD Player Logo
98 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
