Question about Dell Office Equipment & Supplies
Dell M5200n Printer is crinkling Envelopes
When an envelope and only an envelope is sent through the multipurpose feeder, it gets crinkled. Not completely, but you will notice it. Now everything else that is fed through the printer, weither it be normal copy paper, labels, ect, it works fine. It only messes up on the envelopes. Do you have any Ideas?
  • nekojin111 Feb 25, 2009
    Its vertical only. And the guide slide is not to tight against the envelope
    Scholar:
  • 135 Answers
If you have the option to print in Horizontal or Vertical feed, try the Horizontal option and be sure the feed guide slide is not too tight against the envelope.
Posted on Feb 24, 2009
  • My reply is Feb 25, 2009
    Sorry,
    I'm at a loss as to why they come out crinkled.
    Sorry I couldn't be of more help but I tried :o(
    Mike
User printing envelopes from MP tray. Envelope is getting bent and crinkled on the trailing edge. The size meets specs for the 1370dn. What else could be the issue here?
Printing with envelopes is a hit and miss affair. The best ones to use are the ones you have to lick. Dont think of using the ones where you have to peel the strip off. Also make sure you tell the pc that you are printing evelopes as this will allow the fuser to run cooler so as not to melt the adhesive too much. crinkling is usually down to excessive heat.
Jul 05, 2011 | Kyocera FS1370DN Laser Printer
What envelopes will work on a Sharp 3100N? the #10 Grip Seal Security envelopes jam and crinkle.
Most envelopes should work as long as you have:
1) fed them from the right side manual feed tray face down with the short side to the copier.
2) selected ENVELOPE as your paper type to run slower and lower your fuser heat.
The copier is designed for envelopes that have the flap down and the regular wettable adhesive. If you have gummed adhesive with a waxy peel strip that you remove before closing, the copier may not be designed to handle this. It may also help to put the front and rear pressure tabs on the fuser in the UP position.
Dec 15, 2010 | Sharp MX-3501N All-In-One Printer
How to print #10 envelopes
Here's the link to the Lexmark website to download the Lexmark C543 User's Guide. http://www.lexmark.com/publications/pdfs/2007/c54x/v14841473_en.pdf. There are two ways to print #10 envelopes, using the Multipurpose Feeder or the Manual Feeder. If you don't have the Mulitpurpose Feeder, you have to use the Manual Feeder and feed the envelopes one at a time. Scroll to Page 44 for MPF instructions or Page 46 for Manual Feeder instructions. Hope this helps.
Jun 03, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
What does it mean by Load MP feeder letter?
That means whatever you are trying to print is set to feed from the MP tray or Multipurpose Tray. The tray that folds out that is used to feed thicker paper or envelopes in. Just check your print setup screen and tell it to feed from the lower tray or tray1. If that is what you were trying to do.
Dec 28, 2009 | Dell M5200n Laser Printer
Brother HL-5250DN
I had this same problem with a HP Deskjet C4480 inkjet printer. This was happening when I would load one A10 (9x4) envelope at a time.
The problem was solved when I loaded many envelopes at a time. Don't know if this will help but what do you have to loose?
Jul 15, 2009 | Brother HL 5250DN Laser Printer
Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Oct 13, 2008 | Dell 5210n Laser Printer
Dell s2500 printer - multipurpose feeder not taking paper - never been used
I had the same problem and resorted to making sure that there were several envelopes in the tray -- and hand feeding them. I suspect we both have a pickup roller problem, which is typical of the printer, and is the source of a lot of phantom jams.
Mar 14, 2008 | Dell S2500 Printer
Loading envelopes
To load envelopes that are under 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps open and toward the front of the printer. To load envelopes that are over 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps closed and the short-edge of the envelopes facing into the printer. You can load envelopes up to the maximum fill line in the tray at one time. NOTE: Make sure set the envelope flaps are completely unfolded. NOTICE: Never use envelopes with windows, coated linings, or self-stick adhesives. These lead to paper jams and damage to the printer6cf668b.png
Feb 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
172 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
