Question about Intel F301 Original Fan and Heatsink for P4 (C28085-001) Heatsink With Fan
Wont boot past start up to windows
Hi my lappy turns on i get windows xp for about 4 seconds then it goes to safe mode and has 19 seconds reboot then repeats over again thanks
  • 77 Answers
Hiya
when it starts to boot up repeatedly press f8 then u will get a menu, choose last known good configuration.
if this does not work then go into safe mode and uninstall any drivers and reboot to see if that works.
what u may need to do is update your system drivers
rik
Posted on Feb 24, 2009
Why my windows wont boot up past the wallpaper no icons nothin
Could be any number of issues, try booting up in safe mode. If it boots up in safe mode, shut it down by selecting the shut-down option, then try rebooting. If it still does the same go back to safe "mode with networking." Update your anti virus and scan. Then update and scan for malware. Reboot again. If still not going go safe mode again, run fixdisk, if that does not fix it, try system restore to an earlier time and see what happens.if that doesn't work download a program called HDD Regenerator and run it from a CD or USB, it may fix it.
Feb 20, 2015 | Microsoft Windows XP Home Edition
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
Hi, i got a problem with my laptop HP brand with XP OS..every time i turn on it keeps on rebooting even its starting up..i enter start up windows normally but it keeps on rebooting..it goes only until the...
Hi d_gallos,
you may wanna try to go to safe mode (turn off pc then turn it on again while pressing F8) then find there disable automatic restart when system failure then reboot your computer.it should work fine
hope this helps :D
Apr 05, 2011 | HP Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Windows xp starts twice and on second boot wont load user settings
Does it just sit at a blue screen? Is there only one user profile on this system? It could be a bad user profile in which case you can try logging on as administrator (if that isn't the user account issue). Try taking it into safe mode or last good known boot and see how far you get. If you recently installed something software or hardware then it could be related to the installation.
Apr 29, 2009 | HP Compaq Presario V2000 Notebook
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Won't start booting
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
23
Aug 27, 2008 | Toshiba Satellite A55-S106 Notebook
Black Screen
listen the answer is this. screen resolution set to a incorrect setting or video driver installed is not compatible with the hardware in the lappy. what you do is this when you reboot the lappy press the F8 key until it give alist of options boot to safe mode uninstall video driver by going to device manager or reset display resolution in the display setting try the latter first then reboot.
Apr 08, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
130 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
