Question about Sharp AL-1655CS Laser Printer
COPY FUNCTION IN OP
COPY FUNCTION MAKES BLANK COPIES, APPEARS LIGHT BAR DOES NOT MOVE. PRINTER FUNCTION IS FINE. THANKS FOR YOUR HELP
  • billgurd May 07, 2009
    The scanning light did not move across the scanning tray. But the knob was on the lock position.
There is a knob on the left side underneath, above the output tray, that locks/unlocks the scanning mechanism. Sometimes it slips into the lock position by itself. Make sure this knob is turned to the unlock position. You might want to cycle the power to reset everything.
Posted on Apr 03, 2009
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Jan 22, 2010 | Xerox WorkCentre M15 All-In-One Laser...
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Copies are blank
This is most probably a problem with the laser unit on the printer. Try cleaning/replacing it. You will need to take it to a reair agent.
May 19, 2009 | Panasonic DP-150FX Laser Printer
Disable copy function in hp lasejet 3055
You don't want to be able to make copies?
The only way i know is to get rid of the machine, and buy a printer.
Problem solved.
Seriously, you can't program a user code or limit access to this machine. You'll need a different model.
Mar 25, 2009 | HP LaserJet 3055 All-In-One Printer
Light bar does not move. copies come out blank
Have you verified that the scanner is not in the locked position? There is a unlock switch located underneath the paper exit. First power the printer down lock and then unlock this switch then repower the printer and try your scan again.
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Prints and scans fine, but copies are all black
Hold down the auto expsoure key the the lights will began to blink light copies then push it again to hold lighter expsoure.
Jul 18, 2008 | Sharp AL-1642CS Copier
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Sharp AL-1655CS Laser Printer Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
