Question about Kenmore Elite 45986 Front Load Washer
I am getting an error P9. Anyone know what this
I am getting an error P9. Anyone know what this means?
  • Nikki Nicholson May 11, 2010
    What make and model of machine do you have?
  • 15,935 Answers
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Posted on Sep 14, 2010
Hi piz Error code P9 and P21 appears on screen and
check The Transfer Belt or it can be the Black Image Unit . (P9 & P21 normally: black Imaging unit) but P21 can also be refered to Transfer Belt). ..
Aug 08, 2014 | Konica Minolta bizhub C250 All-In-One...
P9 error
well model number would help
Mar 13, 2014 | Konica Minolta bizhub Office Equipment &...
Printing blank
Sir, You have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt, recommended a tech do it, unless you know what your doing
Feb 12, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Presario 6000 desktop wont power up after transporting. Opened cover & I have loose wires that may be the problem. The loose wires are labeled p9 &p7.
Unfortunately, I do not know P9 and P7. Can you tell me if they are multiple colored wires going into a header/connector? If they are single wires or thin wires you may be able to look at your header of wires which connect the pwr button, rst switch, power led, speaker ( 4 pin thin connector ) if p9 and p7 came off here they could be your power switch.
Apr 11, 2010 | Compaq Presario 5000 PC Desktop
I'm receiving an error code "error-02" when i try to play a dvd from the xdv-p9 6 disc dvd player through my avic-n4. What does this error mean?
According to the manual, Error 2 means the disc is either dirty, scratched, upside down, or is of a type that can't be played by the player (i.e. CDROM). If none of the above is true, then there's a good chance the laser lens assembly in the player is either dirty or misaligned and will need to be professionally aligned. I wish I had better news!
Dec 08, 2008 | Pioneer Car Audio & Video
SONY DSC-P9
older cameras didn't support pro cards-if door where card goes in says memory stick anly and not pro you need to find PURPLE card that maxs out at 128mb and that's the only card you can use-hard to find-maybe staples or office depot sometimes or online-if door says mem stick pro try formating card through menu in camera-
Jul 26, 2008 | Sony Cyber-Shot DSC-P9 Digital Camera
Kenmore Elite 45986 Front Load Washer Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
