Question about Maytag Dryers
Dryer stoped running
Smelled something burning and the dryer quit
  • 4 Answers
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Posted on Feb 24, 2009
2 Suggested Answers
  • 16 Answers
SOURCE: dryer quit getting hot
I would suggest that your thermostats/cut-outs have gone as a result of overheating .. Also replace the door switch as this is a safety device to stop the drum from rotating whilst the door is open
Posted on Aug 25, 2009
Ran gas now starts then turns off and smells like burning rubber
Not sure I follow your story. If you really did run out of gas, you may have damaged the fuel pump in the tank. But it would not cause any smells.
Can you tell where the smell is coming from ?
Feb 19, 2014 | 1987 Oldsmobile Ciera
Dryer was running and sparks flew out the back
probably the heating element had a hot spot in the coil of the element and it either sagged from heat and touched the case of the dryer and arced which threw sparks or it just separated with the same results
Aug 24, 2012 | Maytag Dryers
Dryer was working it stoped and smelled like something burning .
You should call a repairman. Sounds like a thermostat that failed and the heat built-up inside the heating chamber until the machine stopped. This would be a gas therm and replaced by a qualified repairman. Unplug the machine and don't attempt to operate it as it might lead to a fire.
Oct 08, 2010 | Dryers
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
Sep 18, 2009 | Kenmore 62602 Electric Dryer
Dryer quit getting hot
Aug 25, 2009 | Kenmore Dryers
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
Dryer will not work
souns like the belt or rear bearing has messed up.
May 11, 2009 | Dryers
Scraping noise with burning smell
You quite possibly have something like a penny or a paper clip stuck at the heat duct. ***First-shut off the electric to the dryer***. From behind the dryer, remove the heat tunnel and clean it out. You will be surprised how much lint gets past the filter. It's an easy repair, just a few screws. While you're back there, look around for any buildup in other areas.
Jan 03, 2009 | Whirlpool LEQ8000JQ Electric Dryer
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Dryers Logo
651 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
