Question about Sony KV-36FS200 36" TV
Sony kv 36fs200 no power 5 blinks - need walkthrough or pics
Suspect that the reason for fail is bad caps would like to have idea of the likely suspects to look at? a diagram or pic with arrow would be best...
  • ftlion Feb 26, 2009
    Well actually I meant more along the lines of where on the tv itself - which board/ what area that might trigger the white balance issue/ 5 blink code?
  • 790 Answers
A buldge capacitor is defective
Posted on Feb 25, 2009
2003 sony trinitron KV-36FS200 video cuts out red light blinks 5 times and comes back on. Sometimes it takes 5 sets of flashes to turn back on.
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 01, 2012 | Sony KV-36FS200 36" TV
Sony kv-32fs120 blinks 3 times then waits and starts a steady 5 blinks over and over. The B+ comes up and quickly off during this
I have not repaired this particular model. If you have a capacitor checker, I would start there. Chances are good you will find a couple of bad capacitors. Bad caps can lead you to an area of most concern. I think the problem is in the general power supply. Check with TVRepair They may have a power supply kit available. Sony TVs are know for wearing down power supplies. The other thing to check, may be the audio IC. Sometimes the audio IC will have a standby mode. This standby is exactly what it says. When you shut off your TV, the standby mode is awaiting a call for power on. These are the two areas to look in to. PS, the power supply is connected to the horizontal deflection, if the horizontal transistor is good, investigate that a bad cap near it is weak or bad. Then proceed to the power supply. Sounds complicated and may be so. As you learn, it is routine. And don't forget, some ofthese TVs are destined for the recycle center! Thanks for asking me. Sincerely, Matt of Matt Martin TV.
Dec 10, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony kv36fs200 its about 8 yrs old. the set takes about 20 min to come on . picture is perfect. do not hear the degaussing coil activate when it eventually powers up . first it was flashing 5...
TV needs screen volts adjustment, screen volt control knob is located on flyback transformer.
Turn On tv and rotate screen volt (G2) control knob clockwise little bit to increase volts to get picture. This problem related with picture tube as its performance seems weak and causing problem.
Aug 17, 2010 | Sony KV-36FS200 36" TV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
SONY KV-20FV10 blinks off
Bad solder contacts on connector/component pins, oxydized connectors, dried up, inflated or blown electrolytic filter capacitors, burnt resistors.
Could be in the main or high voltage power supply, video section power supply, possibly in any of the other sections.
(these are just some ideas)
3rq8 (Triarcuate)
Jul 27, 2009 | Sony KV-20FV10 20" TV
Sony KV-27FS13 blinking standby 5 times..
try to resolder all ic leads and power supply component, moreover Horizontal section.
Jun 03, 2009 | Sony KV-27FS13 27" TV
Sony Trinitron Power Surge 5 Blinks
once you have diagnosed the problem, the following link is to all parts for your tv stocked at partstore. they generally have better prices than the dealers and repair shops.
KV-36fs13 parts
you can try the dead-tv kit from fixyourowntv if you have some basic experience with soldering and circuit repair.
Five blinks means, "IK (AKB)" (white balance). The probable causes listed by Sony are as follows:
1) Video OUT (IC561) is faulty (A board)
2) IC355 is faulty (A board)
3) Screen (G2) is improperly adjusted.
not sure what the 13 blinks are for.
hope this helps,
Nov 19, 2007 | Sony KV-27FV16 TV
Sony KV-36FS200 36" TV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
