Question about Kodak EasyShare Photo Printer 500
Printer to computer set up
How do you install the kodak easyshare 500 printer to your computer without the disk?
    President:
  • 623 Answers
Go to Kodak's web site (here) and download the driver for your Operating System.
...and while you're on it: download the firmware as well (if you need to update it) and save a copy of the manual on your computer. That might come handy anytime...;-)
If you have more questions or need assistance, just come back here and leave a comment.
Posted on Feb 24, 2009
Will printer work with windows 8
Only if there is a Kodak Easyshare Photo Printer 500 Windows 8 printer driver you can install on your computer.
May 17, 2013 | Kodak EasyShare Photo Printer 500
What "Printer" to choose?
Your pronter should have come with a driver disk. You should disconnect your printer from the computer and run the installation from the disk. When prompted, connect the printer to the computer to complete the installation.
May 17, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I cant get kodak 5100 drivers to install
If they do not have a driver on the website specifically for Windows Vista, you could try a Windows XP driver and see if it is compatible. If not, you will not be able to use the printer without the specific Driver software. Hope this helps.
May 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
The Installation disk does not work for Kodak EasyShaare 5500
The easiest thing to do is download the installation for the EasyShare 5500 from the kodak website.
Mar 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can't get picture to scan
try doing this procedure to fix the issue.....
To perform a clean installation of the KODAK AiO Home Center software, follow the instructions below:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the KODAK All-in-One Printer Software:
    a. In the Control Panel, select Add or Remove Programs (WINDOWS XP Operating Systems) or Program and Features (WINDOWS VISTA Operating Systems).
    b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
      • Kodak EasyShare software
      • KODAK All-in-One Printer Software
      • Kodak EasyShare 5000 series all-in-one software
    c. Click Change or Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    d. When the Install Wizard appears, click Next.
    e. Depending on the issue(s) you are experiencing, do the following:
      • If you are experiencing errors with KODAK EASYSHARE Software, such as a tri-code, in addition to errors with KODAK All-in-One Printer Home Center Software, select Remove, click Next, and follow the on-screen instructions for removing the software.
      • If you are not experiencing errors with KODAK EASYSHARE Software, select Modify to uninstall only KODAK All-in-One Printer Home Center Software, then click Next.
    f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
    g. In the Ready to remove the program window, click Next.
    h. In the Uninstall Complete window, click Continue.
    i. Restart the computer.
IMPORTANT:
    • If you selected Modify and only uninstalled the KODAK All-in-One Printer Software and did not uninstall the KODAK EASYSHARE Software, continue to Step 4.
    • If you selected Remove and uninstalled both the KODAK All-in-One Printer Software and KODAK EASYSHARE Software, continue with Step 3.
3. Run the Clear Utility to delete any previously installed KODAK All-in-One Printer Software components:
    1. Got to www.kodak.com/go/clear to download the Clear Utility for KODAK EASYSHARE Software.
    2. Select your operating system from the drop-down list and click the Download button to save the file to your desktop.
      Note: If the status indicator on the Clear Utility stops, check the taskbar on your computer for an active security program. If a security program appears in the taskbar, it may be prohibiting the Clear Utility from running. You must allow the Clear Utility to run on your computer before you can continue.
4. Delete the files and folders that can interfere with the installation.
    For WINDOWS XP OS, delete:
      • Printer folder in C:\Program Files\Kodak
      • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
      • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
      • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
    For WINDOWS VISTA OS, delete:
      • Eastman Kodak Company folder in C:\ProgramData
      • Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
5. Run Disk Cleanup:
    1. Open My Computer.
    2. Right-click Local Disk (C:) and select Properties.
    3. Click the Disk Cleanup button.
    4. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
    5. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
    6. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
6. Shut down all background applications.
    1. Select Start > Run.
    2. Type msconfig in the Open field, and click OK.
    3. Select the Startup tab.
      IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
    4. Click Disable All , then click OK .
    5. When prompted, restart the computer.
7. After the computer restarts, install the latest version of the KODAK All-in-One Printer Software as a free download from the Kodak Web site at www.kodak.com/go/downloads.
    • If the customer has the latest version of the KODAK All-in-One Printer Software on CD, install the software from the CD.
8. Before restarting the computer again, turn on the background applications.
    2. Type msconfig in the Open field and click OK.
    4. Under Startup Items:
      - If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
      - If all background items were originally selected, click Enable All, and click OK.
9. Restart the computer.
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak aio printer 5300/software problem
Greetings Jackie,
Sounds like you have a failed .netframework installation. This is a Microsoft feature, but is delivered during installation of Kodak software as well. To fix this, do the following.
1. Open the Control Panel.
2. Double-click Add / Remove Programs (Windows XP only).
3. Select Microsoft .NET Framework 2.0.
    IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove.
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
    1. Follow steps 1 - 4 above.
    2. Select Uninstall, and click Next.
      IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
    3. Restart the computer.
    4. Perform a clean re-installation of the KODAK AiO Home Center software:
      a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
      NOTE: Do not disconnect your mouse or keyboard.
      b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
        i. In the Control Panel, select Add or Remove Programs (Windows XP).
        ii. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
          • Kodak all-in-one printer software
        iii. Click Change or Remove (Windows XP).
        iv. When the Install Wizard appears, click Next.
        v. Depending on the issue(s) you are experiencing, do the following:
          • If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
          • If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
        vi In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
        vii. In the Ready to remove the program window, click Next.
        viii. In the Uninstall Complete window, click Continue.
        ix. Restart the computer.
      c. Delete the files and folders that can interfere with the installation:
      d. Run Disk Cleanup.
        i. Open My Computer.
        ii. Right-click Local Disk (C:) and select Properties.
        iii. Click the Disk Cleanup button.
        iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
        v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
        vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
      e. Shut down all background applications.
        i. Select Start > Run.
        ii. Type msconfig in the Open field, and click OK.
        iii. Select the Startup tab.
        iv. Click Disable All , then click OK .
        v. When prompted, restart the computer.
      f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
      g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
      h. Before restarting the computer again, turn on the background applications.
        ii. Type msconfig in the Open field and click OK.
        iv. Under Startup Items:
          - If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
      Once restarted, you should be OK.If not call our 800 421 6699 and they will help further.
      Best Regards,
      Ron Baird - the friendly Kodak guy
Sep 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Software Installation problem gets stuck - all in one Kodak ESP3 printer
I have a 6 year old Dell with XP, plenty of hard drive and memory. I could not scan using the software, I went on the Kodak website and followed the Step-by-Step Solutions and Repair which nothing worked, including the Kodak Clear Utility they reccomend for ridding your system of the software, it just locked up at the end.
So, I spent several hours on the phone with Technicians trying to uninstall and reinstall the ESP3 software. None of their methods worked even step by step manually un-installing every file and folder...
So I wrote a nasty email to them and they sent this back, which by the way, didn't work for me either, but maybe it can for you.
According to your email, the issue is that you have not been able to install the software for the printer on your computer. We understand the importance for you to have your printer working properly.
To help resolve this issue, please follow these steps in the order they appear:
2. Uninstall the Kodak EasyShare 5000 series all-in-one software:
a. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
c. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
3. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
a. Printer folder in C:\Program Files\Kodak
b. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
c. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
d. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
b. Eastman Kodak Company folder in C:\ProgramData
c. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
4. Run Disk Cleanup.
a. Open My Computer.
b. Right-click Local Disk (C:) and select Properties.
c. Click the Disk Cleanup button.
d. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
e. Click OK, and then click Yes to delete all files and begin the Disk Cleanup.
f. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
5. Shut down all background applications.
a. Select Start > Run.
b. Type msconfig in the Open field, and click OK.
c. Select the Startup tab.
d. Click Disable All , then click OK .
e. When prompted, restart the computer.
6. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
a. Insert the printer software CD into the CD-ROM drive.
b. In the KODAK EASYSHARE 5000 Series All-in-One Software window, click Next.
c. Select CD Installation, and click Next.
d. Select I accept the terms of the License Agreement, and click Next.
e. Select Custom, and click Next.
f. Select Not Installed for every feature, and click Next.
g. When To begin the installation process appears, click Next.
h. Select Remind me later to register, and click Next.
i. When the Kodak Statistics Collection window appears, select Yes, and click Next.
j. When prompted, connect the printer to your computer.
k. Click Next when the Next button becomes active.
l. When Congratulations, your Kodak printer has been successfully setup appears, click Finish.
m. Click Continue, and then close all windows.
7. Before restarting the computer again, turn on the background applications.
b. Type msconfig in the Open field and click OK.
d. Under Startup Items:
8. Restart the computer.
Aug 30, 2008 | Office Equipment & Supplies
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
c. Delete the files and folders that can interfere with the installation.
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare Photo Printer 500 Logo
104 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
