Question about General Electric WBSR3140GWW Top Load Washer
Washer does not spin or agitate at all. Timer works.
Washer is only 5 months old. 2 loads a week. Pumps water in and out fine. Doesn't make any strange noises. The only thing it doesn't do is agitate or spin.
  • Anonymous Mar 23, 2014
    Washer not spinning
  • General Elec... Master
  • 3,361 Answers
Check your belt. It may have become loose.
On the top right and left of the front panel insert a putty knife about 3 inches in where the top meets the front panel.
This will release the front panel so that you can see the motor and belt operation.
Better still, a 5 month old machine call for factory authorized service.
Posted on Feb 24, 2009
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My 5 year old LSQ9659LW washer pumps but no spin
You could have two problems here. One is a bad timer not giving the signal to spin and the other burning smell is usually a belt slipping on the drive shaft. Either way, it's time to have it checked out. If it it's a newer model without any belt the electric motor is heating up and this definetly needs to be checked out.
Sep 17, 2009 | Washing Machines
My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
Hi there. I can help you.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
Jun 18, 2009 | GE WSXH208A Front Load Washer
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
General Electric WBSR3140GWW Top Load Washer Logo
351 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
