Question about Frigidaire Dryers
Dryer won't heat but still runs.
I need help replacing part #131553900 (heating assembly) in my part # GLER642AS3 dryer.
  • 2,920 Answers
It sounds like the heating element or the limit switches are out on it. they arent very expensive if you know how to install them
Posted on Feb 24, 2009
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
My dv210ae dryer runs but won' heat
It's likely your heating element has overheated and the ni-chrome heater wire has been severed. There are other potential root causes, but this is most likely the root cause. There are two temperature sensors in the heating element sub-assembly, one or both or which may have failed.
The most likely cause of heating element overheating is a clogged vent. To avoid future overheating, check the vent regularly and remove any lint build-up.
The heating element, the heating element sub-assembly, and the entire galvanized metal heating sub-assembly (which includes the two temperature sensors) are available for purchase. Here are examples of all three:
Before purchasing any component, verify model and part numbers match your dryer.
Before starting your repair, make sure the dryer is disconnected from its electrical source either by unplugging it or turning off its breaker. The dryer is heavy, so be careful lifting. Parts inside the dryer may be sharp to the touch, so be careful reaching inside. Use of gloves is recommended.
The heating sub-assembly is accessible from the front, behind the door sub-assembly, but may need to be removed from the rear. Follow this YouTube example-- it should be similar to your dryer even though it may not be exactly your model. Be sure to notice wires and cable connections, and be sure to reassemble just as you disconnected. It's wise to take photos as you go so that you can recall how parts and wires go back together.
If the heating element is severed, obviously it will need to be replaced. If the mounting insulators are in good shape, you might choose to just replace the wire. As in this video, some skill is needed to disassemble the heating wire from the mounting plate. If one or more insulators have been damaged, the entire heating wire sub-assembly should be replaced. Or, as listed above, the entire sub-assembly can be purchased, which includes the two temperature sensors. This will simplify the project (but cost a bit more). The temperature sensors should be in normally-on condition, going to open state at temperature set limit. You can check the sensors with an ohm meter. If either is open at room temperature, that sensor has failed and also needs to be replaced.
Make the repairs warranted by your investigation, re-assemble the heating sub-assembly being careful to match photos you've taken, re-install in the dryer, re-assemble the dryer vent, door and top, re-connect the dryer to its electrical source, then test the dryer. The temperature should quickly rise within the dryer drum.
Apr 01, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Frigidaire model# gler642as3
-You mean it work like normal but just no heat all ?
-If so check for heater element. It could be burn out.
Good luck
Dec 14, 2013 | Dryers
Dryer runs but won't heat
You will need a professional to diagnose the thermal limiter, small version of a fuse, heating element and the dryer/blower assembly.
Aug 17, 2012 | Frigidaire Electric Dryer
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
Sep 10, 2011 | Frigidaire Dryers
Friidaire Gallery Dryer, Model # GLER642AS3, S.S. # XD50808416 does not heat when in operation
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Oct 14, 2010 | Frigidaire Dryers
Frig. model# gler642as3.. No power. No light.
Go to the parts you need to check are F15, F33 and F36. F15 is the element. F33 is the High limit thermostat and the F36 is thermal limiter. The most common problem with these dryers when they are not heating is a bad thermal limiter (F36) F33 would be my second guess and the element would be my next. Either one of these could be causing it not to heat. Good luck
Dec 15, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire GLer642As3
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
May 12, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
195 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
