Question about Panasonic PT-50LCX63 50" Rear Projection Television
Have a 50 inch Panasonic Rear Projection. The Red is so far off to the left, that we cannot get it realigned. Its gonna cost btwn 200 and 400 to fix. Before I decide to buy a new one, can anyone help??? Blue and green are where they should be, red is off to the left. Thanks!
  • amylynn08005 Feb 24, 2009
    yes, we know that, the red will only go so far and not "match up" with blue and green.
    Genius:
  • 2,920 Answers
I would go ahead and have this one fixed if its new enough,,,its in the convergence board where the problem lies and would be cheaper than buying a new tv
Posted on Feb 24, 2009
After moved the TV, you can tell the top and bottom lins is not straight, tilt to the center screen
You need the Red Green and Blue lights realigned in the rear. Usually costs 200-500 and not worth it on such and old TV. Go to Wal-Mart or online and buy a new Plasma/LCD!
May 02, 2011 | Toshiba 50HX81 50" Rear Projection...
I have a Panasonic 62 inch rear projector tv and the lamp light is turning red so my tv will not turn on, i was told its either the bulb or a dirty filter the question is where is the filter
It's most likely the Bulb. We had the same issue with ours only 1 year after buying it. Luckily we purchased from Costco and called them. They had someone come out, replace it and didn't cost me a dime. (When I called Panasonic they said the lamp was covered under the 5 year lap warranty, but the labor for someone to come out was going to be $100.)
Mar 13, 2011 | Panasonic PT-50LC13 50" Rear Projection...
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Red blue and green not lined up
56 inch panasonic tv has blue yellow lines running up and down on right side
Apr 09, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Anyone know how much a light engine might cost for this tv panasonic PT-50LC14 50 In.
to be honest save your money and buy a new tv, by the time you purchase it and install it , your still gonna run into more problems.
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
2 thin blue lines on left h side of humax 32tpvr
IN THE MENU FOR COLOR CONVERSION TO REALIGN THE COLORS
Dec 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Hitachi 50" - 50GX30B
You will need to replace the convergence IC inside the TV set.
Aug 12, 2007 | Hitachi 50GX30B 50". Rear Projection...
Panasonic PT-50LCX63 50" Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
