Question about Indesit W 123 Front Load Washer
Won't spin on last cycle
Unable to find out how to clean out the filter, bought the machine about 10 years ago, unable to find instruction booklet. Also the machine leaks
The pump is supposedly self cleaning.
There's a 'pre-chamber' behind a panel at the bottom on the front. The top of the panel should tilt forward & up. Turn the 'pre-chamber' anti clockwise, after putting a shallow tray under it to catch the small amount of water that may be there.
I think I have a pdf manual (found on web somewhere) on another computer, I'll have a look & send it to you if you can give me an email address.
Posted on Feb 28, 2009
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
I have a Bosch Classix 6 1200 Express that stopped working 23 minutes before the end of the cycle. It has been noisier recently but this time it stopped altogether and when I tried to spin the clothes the...
Hi davidandsall,
Before it can Spin (The last part of any cycle), it would need to drain the water first. Your machine is stock on that particular position, most likely because of a clog in the Drain Filter compartment.
You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Washing Machines
CRYSTAL LORD 909 not dry spinning or pumping out water
You're the 3rd person to log this problem in 10 minutes!!
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Washing Machines
Hi I have a Westpoint XQG50-604 frontloading washing machine. It's approximately 10 years old. I have 2 problems. 1. If I turn the dial of the hot water selection, it doesn't wash or start to wash...
1) sounds to me as if the hot water inlet valve is malfunctioning- not opening when told to so requires replacement ;-0)
2) my pre-typed general guidance notes which follow are worth carrying out!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 02, 2011 | Washing Machines
1)when cycle reaches final spin cycle (about 10 minutes remaining) it will attempt to spin for a few seconds and then stops. It displays no Code Symbol, it shows the remaining 10 minutes. 2)Remove all...
Sorry but this is always where I start with funny problems like this and so many times it has cured problems ;-0)
John C
Feb 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
Nd appears onscreen
First drain out the water from the machine with a tube. You have to check your outlet filter, likely it is clogged. Clean out and refit. Your machine will not do the spin because it knows the filter is clogged.
Jun 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Indesit W 123 Front Load Washer Logo
161 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
