Question about Rockford Fosgate Audio Players & Recorders
How to bridge a punch 3001 car amp
How do you bridge a rockford punch 3001 car amp down to 1ohm and what is the max wattage?
  • 39 Answers
You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
Posted on Feb 26, 2009
  • NotTelling Feb 26, 2009
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Hey i was wondering on the model punch 325.1 rockford amp what positive and negitive hook ups do i use for bridged channel.
the amp is a mono block so there is no bridge mode. The 2 speaker terminals are provided for easy connectivity of multiple speakers
Jun 05, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
Need amp for 2 15 l7 4 0hm
Hello jasonjohnson,
There would be more amp choices if those L7's had the 2ohm voice coils, allowing you to series the coils and then run the subs parallel to the amp for a 2ohm load. As it is, you'll probably have to run them as either 1ohm and have limited amp choices, or as 4ohm and settle for a little less power.
An absolutely excellent amp to use at 4ohm would be the Alpine MRP-M1000. At Crutchfield this one is on sale for $347. For more power, and an amp stable to 1ohm, I would recommend the Rockford-Fosgate Punch 1000-1bd, a "factory refurbished" model is available at Crutchfield for $349.99. It's $700 new.
Both of these amps have adequate power for 2 L7's, but the RF will definitely be the better power choice. Both are also well respected names in mobile audio and the prices are reasonable.
If you have deeper pockets and want to push the subs really hard, a Rockford-Fosgate Punch 1500-1bd will put a full 750 watts RMS to each sub.
Hope this helps.
May 02, 2009 | Car Audio & Video
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Rockford Punch 550.2 amp wont play
The amp is blown and need to be repaired.
You can contact Rockford direct to find a repair dealer.
Apr 16, 2008 | Rockford Fosgate Punch P550.2 2-Channel...
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
196 people viewed this question
Top Rockford Fosgate Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rockford Fosgate Audio Player and Recorder Expert? Answer questions, earn points and help others
