Question about Panasonic CT-36SX31 36" TV
PANASONIC CT36X41X FLAT SCREEN
The tv quit, I unplug it and put it on again and work for a few minutes, after a few minutes working quit again, i put a manual swith in the line when the tv go off i just swith off and on and start working again, i look in the clock set up and gave me a message that the tv is working in
auto power mode, i do not know how to fix that, i need help,
it is a fuse or a relay or the fly back some body gave me a solution thanks
    Sergeant:
  • 326 Answers
Just check wether its set to some sllep functionality that turns off the tv after particular time of being ON.make it to normal and check before we carry on to further diagnosis.
Posted on Feb 24, 2009
    Scholar:
  • 124 Answers
I have had the same TV like you and had the same problem. The problem is that the Power Board and the Fan's failed and need to be replaced. After I replaced those on the TV, the TV worked great. I hope this helps!
Thank you for using Fix Ya!
Have a Great One!
    Top Expert:
  • Panasonic Master
  • 77,499 Answers
YOU HAVE A SHORT IN THE HI VOLTAGE CIRCUIT, THE TV IS SHUTTING DOWN DUE TO EXCESSIVE CURRENT DRAW, THIS IS A SAFETY FEATURE, YOU SHOULD NOT BYPASS IT, U WILL NEED TO REPLACE THE HIGH VOLTAGE POWER CIRCUIT BOARD, A VERY COSTLY PART.
  • Panasonic Master
  • 19,396 Answers
Leave it unplugged for longer , at leas thirty minutes.
  • Ginko
    Ginko Feb 24, 2009
    To disable auto power go to CONVENIENCE FEATURES menu using your TV remote and set Auto Power off.
Grandson put a penny into the SD slot while the TV was on. It immediately stopped working.
This happened to me yesterday. My daughter put a penny and a dime in the SD slot and none of the buttons or volume were working on my TV.Only the power button would work.
I fixed it by simply removing the penny and dime out of the SD slot and then i held the power button for 10 seconds. After I unplugged the TV from its power source for 5 minutes and then plug it back in. When I turned the TV back on everything was back to normal.
For a second I thought I was going to have to buy a new TV, lol. Hope this helps. If it doesn't work the first time then try it a second time.
By the way I have a Panasonic PT-52LCX66 LCD Projection TV..
May 02, 2011 | Panasonic TC-P46G25 Flat Screen Plasma...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Oven will not bake but everything else works fine
What is the red light blinking? Count the blinks before it pauses and post back here. It'll give me and everyone else a starting point.
Jan 21, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
MY PANASONIC FLAT SCREEN VOLUME AND TV CONTROL DOES NOT WORK!!
Try unplug the power cord while the tv is still on. plug it back after 5 mins. it should work.
Aug 23, 2009 | Panasonic TH-42PX60U Television
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Open Questions:
Panasonic CT-36SX31 36" TV Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
