Question about IBM ThinkPad T20 2647 Notebook
Extended my monitor to a Vizio 37" LCD TV Echoed Sound
I have my PC connected to a Vizio LCD using a standard VGA to RGB connection. The sound is awful and sounds echoed using a standard audio speaker cable from the tv to the speaker (green color coded) jack on the back of the PC.
There is also a HDMI connection on the video card, will this work and will it transfer sound for the tv and the computer.
Keep in mind the LCD is only an extension of the PC monitor and is not used for TV purposes.
Any help would be nice...
    President:
  • 623 Answers
You have an HDMI connection on a Thinkpad T20???
Per definition, HDMI is supposed to send video and audio data from the TV to the PC -so, yes, it should work.
I say "should", because I tried to hook up my PC that way and I went back to a VGA connection (and sent the sound to an old stereo), because the resolution was awful.
I rather think that the audio cable is the culprit here - if the connectors are not fitting perfectly, they can create a lot of distortion.
Also check your audio settings on the PC (updated driver, settings not on maximum volume, etc.)
If you want to try HDMI, there is no need to get the ultra expensive "Monster" cable. Look here for an example.
Posted on Feb 24, 2009
Are you able to use the VIZIO 47" Class 1080p 480Hz SPS LED Backlit LCD HDTV as a computer monitor and use a wireless keyboard and mouse to browse on a pc through rgb and speaker jack?
Yes, all new TV's of 1080p specification will have a dedicated PC connection (and should have either a 3.5mm audio socket or 2 x RCA inputs for audio).
The most common way is to use a VGA lead (with 3.5mm audio lead) - VGA out of pc to VGA in of TV. 3.5mm audio output of pc (ie headphone socket) to 3.5mm audio input of TV.
You will just require the correct VGA lead long enough to connect to your pc.
The wireless keyboard and mouse will need to be connected to your pc, and must be within "line of sight" to the wireless receiver.
If you specifically want to use pc output to RGB input (and RCA audio in) of your TV, then you will need to obtain a long VGA to RGB conversion cable, plus 3.5mm audio lead. Have a look on Ebay for a coversion cable.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | Televison & Video
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
What's no rgb connection mean?
This is mean your TV can not use as Computer monitor because no VGA connection port on your TV.
Regards, vote please, Jay
Feb 21, 2011 | Vizio L32 32 in. LCD HDTV
I can watch a movie from my computer to tv but the sound only came from the computer not on the tv
if you want the sound from tv, get an audio cable and put one end to computer where the speakers connected and the other to the audio input or aux in back of tv.
good luck hope it works, if so do rate the solution
Nov 28, 2010 | Vizio 42 in. LCD TV
How to I connect my Haier tv to my pc and have it act as my monitor?
If you have a standard video card on you p.c, that is with the 15 pins vga connector, all you need is a standard vga cable .Connect it in the pc in at the back of your monitor and turn the monitor on, with no other input connected to the set it should autodetect the pc.for the sound you`ll need a 1/8" phone jacks stereo cable connected to your sound card. have fun
Nov 03, 2009 | Haier HLC22R1 LCD TV
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Jul 18, 2008 | Vizio L37 Television
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
IBM ThinkPad T20 2647 Notebook Logo
407 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
