Question about Car Audio & Video
Car stero doesn't come on
Have a problem that the car stereo just shuts down, un plug fuse and the stereo starts and plays normal, the last time it happened,pulled the fuse, and reinserted it, came up with "code off"," all off," and the time comes on , not able to turn stereo on or adjust time on clock, never activated the security code feature on the radio, i hope thats not it
  • 57 Answers
You have it wired wrong. With the fuse out it is like disconnecting the wire, thus removing the fault. Be glad it is shutting down. It is protecting itself from damage and electrical overstress. Trace the wire, my guess is it is a power wire that is grounding. Check all of your wiring again.
Posted on Feb 28, 2009
Systemax Tiger
Hold down power button un till it shuts down,normally works if that doesn't work take out ur battery and un plug mains adapter, if its a desk top just un plug it and leave it when u re start keep pressing F8 then select return ur comp to a earler time this will sort it out
Nov 06, 2013 | google.com
Windows will not start on my laptop
2 choices turn the comp over un plug the battery leave about 2 minits.
then plug back in and try again .
If that doesn't work then when it starts 2 boot up press F8 several times it will ask normal start or select last known good configuration & select it . if that doesn't work have u aback up disk insert the 4 th disk and boot from that insert tha disck turn off comp and re start it will come up boot from disc press any key yes thats shold b it
Oct 02, 2012 | Sony VAIO Computers & Internet
I was installing an amp for my subs and forgot to disconnect the remote wire I had tapped into the deck. My son pulled the wire n it hit metal and Tue stereo shut down. Now it has no power to Tue stereo. ...
There should be a fuse on the radio. If not check any fuses inside the vehicle; normally by the driver kick area. If this doesn't help, I guess you know the rest.
May 20, 2012 | Pioneer Car Audio & Video
I was hooking up a stero in my 2000 cadillic deville when a spark occured now the system is completely dead
Afternoon, the stereo has a fuse, which has blown. They are usually found on the positive side of the wire for the main power to stereo , if not that one, it is the fuse inside it. The ones I have fixed are very tiny, not standard size. Next time, disconnect the battery or put tape over the ends of the wires. good luck. You are not the first to do this and you certainly will not be the last so do not feel too bad. (Australia)
Jan 15, 2012 | 2000 Cadillac DeVille
I want to know how can I play my iphone through my kenwood car radio.
Well depending on the model of your stereo you could either connect with blue tooth or with a usb cable. Some stereo's have a mini jack on the front of them you could plug into. If your stero desn't have any of these options then you can buy a variety of FM transmitters that connect to the iphone and transmits the signal to a certain FM frequncy like 89.5 or something like that. Just google Iphone accessories or take a look at your local electronics place. Also google the model number of your stero and you should be able to get some info on your stero and the options that it has.
Sep 21, 2010 | Car Audio & Video
How do you check the fuse on my dual car stero
it shud be in the back of ur unit rite where the wires are ,plug th wires off & ur fuse shud be rite there.
Jul 12, 2009 | Dual XDMR-7700 CD Player
The fan on my 2004 SAAB 93 convertible will not shut off.
I would suspect that the cooling fan relay ( in a relay / fuse box under the hood) is stuck. There are 2, a high and low speed relay. Pull one and see if the fan goes off. Once you have identified the culprit, see if there is an identical relay in another location that you can swap into place to verify the problem is fixed.
Mar 24, 2009 | 2001 Saab 9-3
Stero not coming on
What kind of car do you have? This can make the difference. Many cars with small engines (eg. Geo Metro) simply do not generate enough power to operate the radio. Other times the car can generate enough power to support the radio, but when you plug something into the cigarette lighter/power outlet the radio shuts off because the car isn't powerful enough to handle both. The first thing you need to do is to make sure that the car's electrical output is sufficient to operate the radio, after that it would be a good idea to make sure that all of the wires are connected properly.
Oct 29, 2008 | Pioneer KEH-P4020 Cassette Player
Instrunment panel and stero
when i take out my key,, everything is lit up.. and music playing.. but when i open the door.... i get out... all things going in the car shuts off... I would suggest.. turn off a/c,,,, stereo, etc.. before you get out of the car..until you can get to the dealer and have them check that door connection to turn things off...
May 24, 2008 | 2004 Oldsmobile Alero
Lexus ls400lexus LS400 nakamichi cd car stero AMP troubleshoot
reset the 3 breakers located near the fuse box by putting a tiny pin into the slots till you hear a click.
Apr 26, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
