Question about HP PSC 2355 All-In-One InkJet Printer
Paper jam error 0x805d1309 2670:fm_keywords_cm.c
  • 979 Answers
Unfortunately, this will be a tedious task but well worth it in the long run. You have torn off paper and chunks in there. Take a paper clip and try to pull out those pieces. You have 2-3 places you can access the paper. Open the door to it and look for it with maybe a flashllight. Turn off your printer first so it won't activate. This may take 30 minutes or so. Most of where you will find the paper is where it is pulled into the machine at the rubber wheels. Let me know how this works for you.
Posted on Feb 24, 2009
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon Pixma MX300 printer had a paper jam. I took out the paper, and it was all there with no missing parts. It continues to say there is a paper jam - there appears to be no reason for the jam. I...
Try checking that a foreign object is in the paper feed rollers- do this by inserting a thin piece of plastic about 2 cm wide through the rollers from the paper exit side. Plastic like that from a shirt box (about 2cm wide by 20 cm long and 1 mm thick works well. I have solved this problem many times with my mx300 and it clears out objects which have droppped into the paper feed, such as Pens , yes pens. and paper clips etc which are otherwise hard to detect on this printer.
Sep 25, 2010 | Canon PIXMA MX300 All-in-One Printer
My printer keeps saying there is a paper jam in tray 1 but I don't see anything. (HP 1312 nfi)
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Sep 21, 2010 | HP Laserjet CM 1312NFI Color Printer
I am getting paper jam error message after I try to print on photo paper
Some printers detect the type of paper you are using, and print accordingly. Do you have photo cartridges installed? If not, that will trigger an error message. Try putting a smaller amount of sheets in the paper feed- that can sometimes trigger an error message, I've read in reviews. Double check the printer to make sure there, indeed, isn't a paper jam. The type of paper one uses with certain printers can be an issue, so google your printer make and model number and then type something like suggested paper type, or things similar, and you will get some sites that discuss problems with different printers and paper types, and also suggestions of which paper will work well with which printer.
I couldn't find any specific information since I didn't have a make and model number, but hope this general information helps.
Good luck, and thanks for using FixYa.
Sep 07, 2010 | Office Equipment & Supplies
Problem with Canon MP600
I had the same problem with my Canon Pixma MP610.
After stripping the printer down I found there is a lever in the path of the paper that operates a photo electric sensor. This can get stuck in the wrong position. To reset it get a sheet of A4 paper or (better) card fold back a 1 cm strip on the top edge of the paper and press it down flat. Open the rear cover and insert the sheet folded edge first and folded flap upper most over the top of the upper set of rubber rollers. Push it into the machine as far as it will go and then withdraw it. You should feel a little resistance or here a click as the lever is reset. You printer should now work.
Several hours of frustartion and foul language have brought you this fix. I hope it works for you.
Regards
Jon
Jan 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
The paper crinkles and jams. I have opened the from escape door and the paper feed through OK but does make a tick on the leading edge of the paper 2 1/4 Cm from the right edge. It looks a though there is...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 15, 2009 | Lexmark E220 Laser Printer
Epson Stylus cx5 series
Is media transparent? Epson paper sensor think that no paper. Put white stiker at top left and right of media (about 1 cm height and 2 cm width). It's for tricky sensor.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
272 people viewed this question
Seeker5211
Seeker5211
