Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Ice maker not working but are getting water from dispenser.
Just this last week the refrig was making a funny noise. Noticed that the ice maker is no longer making ice and the arm is down in the make ice mode. The arm starts to rise but nothing happens. We are getting water from the dispenser though. Any thoughts. Much appreciate it.
IF YOU HAVE THE SAME FREEZER AS MY MOM HAS THEN I MAY CAN HELP YOU OUT. FIRST OFF WHEN YOU OPEN THE FREEZER PORTION (SIDE BY SIDE STYLE) YOU WILL SEE THE ICE DISPENSER. TAKE THE PART OFF WHERE IS SHOWS YOU: TO MAKE ICE MAKE SURE ARM IS DOWN AND TO STOP MAKING ICE RAISE ARM. THAT IS A COVER THAT WILL COME OFF WITH NO TOOLS NEEDED. ONCE YOU OPEN THIS YOU WILL SEE A METAL FRAME WITH A WHEEL IN THE MIDDLE THAT SAYS DO NOT TURN BY HAND. LOOK IN THE MIDDLE OF THE WHEEL AND SEE IF THE ROD IS BROKEN (FOR EXAMPLE MY MOMS HAD A CLIP ON THE ROD THAT WAS BROKE AND WOULD NOT ALLOW THE DIAL TO SPIN WHICH THEN MAKES THE ICE MACHINE SCOOP THE ICE OUT OF THE BOX) CHECK THIS WHEEL TO SEE IF IT IS STILL IN TACT. THIS COULD BE YOUR PROBLEM.
Posted on Mar 18, 2009
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Ice maker not filling with water or making ice- GE pfss6pkwss
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 01, 2009 | Refrigerators
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and water stopped dispensing
some models of this refrig have a lcok out feature on the dispenser look for a padlock symbol on the dispenser console and make sure its unlocked. if it s not locked out you may have a broken switch bracket behind the console cover. when you press the levers listen very closely and you should hear a click noise letting you know the dispenser switch has activated. Let me know if you have any further questions thanks Peyton
Mar 07, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker will not make ice
the ice maker is not making ice but the water is still working
Jan 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
218 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
