Question about LG WD-14124RD Front Load Washer / Dryer
LG 1412RD Tips main fuse. Halfway through wash tripped fuse in fuse box, now if plugged in trips fuse without even turning machine on.
  • janspicer Feb 25, 2009
    I have tried other appliances in the power point without any problem. Have run an extension cord to another circuit from washing machine, as soon as power point turned on trips that fuse as well.
  • 979 Answers
You have a dead short either in your breaker box or the plug in. Chances are it is your receptacle.
Posted on Feb 24, 2009
  • Bill Dickerson
    Bill Dickerson Feb 25, 2009
    Thank you for trying that. You have eliminated half of the possibilites. What has happened is that there is a wire that has either come loose or has burned in two. The wire is probably touching something else which causes an immediate trip. Now take off the back panel of the washer and begin to look inside. Make sure you have unplugged it first. Trace the wires from the plug that goes into the receptacle. The plug itself may be the problem. Take it apart and see that there are no loose wires touching anything. It should all be snug. Next, follow the wires up to the terminal in back of the washer. More than likely, it is in one of these 2 places. You also can look up inside and see if any wires have come loose as well. Let me know how this does.
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
Indesit washing machine does not turn on
If it's tripping breaker, there is a wire shorted somewhere.
Nov 07, 2017 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Aug 15, 2009 | Washing Machines
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Washing machine keeps tripping electric switch
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
LG WD-14124RD Front Load Washer / Dryer Logo
553 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
