Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating
My GE SpacemakerXL microwave oven - model jvm1640 1,000 watts is not heating up anything that is put in
  • GE Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
Ge spacemakerxl microwave jvm1650 vent is not drawing air
It is possible, you have removed and checked the filters, still the intake is low even without the protective filters. The system will need to be taken apart to find the opstruction, or as you said a hole in the venting mechanism.
Jul 04, 2012 | GE JVM1650 1000 Watts Microwave Oven
I have a GE SpacemakerXL microwave that stopped working after I heard a loud pop. Everything else works, but it does not heat anything. Help?
From the descriptions it likely the magnetron has failed. If you have a digital multimeter post me a comment and I will give instructions to do a rough test.
Jun 06, 2012 | GE Profile Spacemaker Over-the-Range...
GE spacemakerXL microwave JVM1650 w touch screen Hi speed not working on external vent fan
It seems like the control panel is malfunctioning. The censorfor external vent fan may not work due to faulty control panel. You need toreplace the control panel, so that microwave will work properly. Replacing anERC is not a difficult repair and can be accomplished by the average do-it-yourselfoffer. Hope this will help you. Good Luck.
Aug 06, 2011 | GE JVM1650 1000 Watts Microwave Oven
Microwave will start then make a different sounding noise and will not heat anything that is put in the unit
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 16, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE SpacemakerXL Microwave Oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave stopped working
Sounds like it blew the fuse, and when the fuse blows immediately upon hitting the START button, I'd say you have a shorted high voltage capacitor. But it may also be an open thermal cutout on or near the magnetron or just a fuse. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like JVM1860B01, not XL1800 or Spacemaker) here: http://tinyurl.com/gv383
May 05, 2007 | GE ZMC1095SB 800 Watts Convection /...
GE Spacemaker JVM1640SJ Microwave Oven Logo
126 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
