Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Sink was pluged plunged and now the dischwasher will not fill it's keeping draining the water out all the time
  • 117 Answers
Bosch has a safety float switch under the dishwasher basin. If water leaks into this area, the float rises and turns on the drain pump to clear out the water in the dishwasher. Hope I explained that ok :)
Anyways, usually a leak somewhere causes this and unless the leak is fixed and water is removed or evaporates, the dishwasher will remain in the drain cycle.
Posted on Feb 25, 2009
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux dishwasher overflows
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. ...now it...
hi,
the unit will not fill with water until it will drain as it needs to complete the drain function before it can move onto the next step.
make sure the non return valve under the filter is properly fitted in the sump of the unit. then check the drain spigot under the sink where the drain hose connects to the sink u bend. This is the most common causes of a blocked drain.
Nov 28, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Sink drain slow
You can purchase a device from Home Depot that will clean out the drain. In the plumbing business, we call it a blow bag. But some call it drain dog and so on. It's a black rubber bag that fills with water and then when it reaches a certain pressure it blocks the drain but runs water through it until the clog is dislodged. You attach it to a water hose and push it into the drain as far as you can get it. Run it for 15 to 20 min. and then pull it back out. There are several sizes to accomadate the pipe size. You sill need the one that does pipes up to 2 inches. You will have to remove your drain assymbly under the sink to do this. While you have the drain assymbly off, you can make sure it is clean as well. This will clean out the garbage that collects in the pipe. Hope this helps.
Mar 20, 2009 | NRS A.H. Undermount Large and Medium...
Not filling
check the base of the dishwasher for water. remove the toe kick at the bottem and soak up the water down there. its probably activating the float switch. im assuming you had a drain problem with the sink? so the dishwasher couldnt properly drain.
Jan 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
274 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
