Question about Linksys Wireless-G WRT54GS Router (e125894)
Router has stopped routing
The router has been in use for almost two months and has been working fine things started acting up last week so today the provider has came and checked their equipment and it is operating properly.when the problem began I could reset by unpluging power and it would work again,but now the only way I can get connected is to disconnect the router and connect the cable directly into the computer. The network shows that the router is connected through the computer that is hard wired through the router,but will not connect to net and the laptop will not connect either unless I bypass router and connect directly with the cable fom my dsl provider
    Sergeant:
    Champion:
  • 435 Answers
Hi, Check to fix with the router's warranty.
Somethings that you could try yourselves are:
- Disconnect the router and power it down. wait for 30 secs and switch it on.
- Go into the router settings and change the transmitting channel to either 1,6 or 11.
These steps are to avoid air traffic congestions.
Posted on Feb 24, 2009
Car wil not start will not turn over at all. the radio and lights work fine, battery was replaced about 2 months ago
check the battery cables are not loose at both ends. when the battery was replaced you may have loosened the cable at the starter end or the ground end?
Dec 15, 2013 | 2006 Hyundai Sonata
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
ASUS RX3041 connection problems
For whatever reason, your router is having trouble handling the traffic with both computers running at once.
This might be a small issue concerning the routing table.
Since it does still work generally, I would try simply reseting the router.
There should be a small pin hole on the back of the router to reset it.
Thanks,
Pat
Apr 08, 2010 | ASUS RX3141 Router
Gaggia Titanium - Cold coffee although producing steam.
The only thing that comes to mind is one of the thermostats on the boiler.
Jul 19, 2009 | Gaggia Titanium Espresso Machine
PPTP VPN stops working through Comcast ISP on July 15
comcast will take a long time to fix, around 4 months
Jul 19, 2009 | Computers & Internet
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Jan 27, 2009 | Linksys Wireless-G Broadband Router
Electrical problems
I have, when I first bought my 02 Liberty. It ended up being a faulty ECU. ECU is the computer brain that controls the whole car. I had it replace and it never happened again.
Sep 09, 2008 | 2002 Jeep Liberty
Wireless router keeps loosing connection
go to wireless device and re-configure it
Jun 14, 2008 | Dell Wireless 2350 Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
63 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
