Question about Toshiba 32DF46 32" TV
Help me. i have a Toshiba 36a43. I turn tv on it
Help me. i have a Toshiba 36a43. I turn tv on it will only stay on 5min maybe. What's the problem?
  • 790 Answers
Hi
maybe you have weak filter capacitor! at the regulated power supply in cold area..
Thanks!
Posted on Feb 25, 2009
Hello, I have a TOSHIBA 36" Model # 36A43 and it will not turn on.. the past few weeks i have been experiencing problems with the remote.. like not turning off the TV or the volume. Once in a while it
The manual power button ought to still turn the set on and off even if the remote is bad or not working.
I suspect you have two problems but there is a tiny chance only one as the front buttons and the remote both go to the same place in the set but here the front buttons have priority.
Dec 04, 2012 | Toshiba 36A43 36" TV
Need a manual for a TV model 36A43 serial # 14884246
Retrevo has the manual for the 36A43 here: http://www.retrevo.com/support/Toshiba-36A43-TVs-manual/id/311ag723/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Oct 09, 2011 | Toshiba 36A43 36" TV
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
The problem is most likely the switches on the front panel. If the manual buttons are constantly shorting out, then the TV will try to respond to those buttons, and not the remote. Manual buttons almost always override a remote. Check the front panel for shorts, or if the buttons are constantly depressed.
Dec 13, 2009 | Toshiba 36A43 36" TV
I was watching tv when suddenly the volume control indicator bar showed up and started going up and then down and the remote will not operate the tv. the set it self will allow me to change channels and...
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jun 26, 2009 | Toshiba 36A43 36" TV
Brief Startup Problem
the tv has an intermittent problem in the video circuit and related circuit.it could be some cold solder that needs to be resolder.contact the tech to do the repairs.good luck
Apr 03, 2007 | Toshiba 36A43 36" TV
Power surge I think
If you do not get any clicking or sound when trying to turn on the TV set, most likely the main fuse went out. This is almost always due to something else blowing out along or making the fuse to blow out. DO NOT SIMPLY REPLCE THE BLOWN FUSE! If there is other shorts inside the set, and you replace the blown fuse, you can cause more damage to the TV set. The best way to test this set if the fuse is blown would be to hook up a 100 to 150 watt light bulb across the blown fuse, and if there is a short in the TV set the light bulb will glow bright and stay bright. If the bulb lights up and goes dim maybe just maybe you got luck so replace the fuse and see what happens. If the light bulkb stays bright, there is a short in the set somewhere and if you do not have a service manual and a good multimeter and a knowledge of how the TV power supply works, you really should call in a pro to assist you in the repair of this TV. there is just too much High Voltage inside these TV sets to be experieenting around inside of it. Good Luck.
Mar 14, 2007 | Toshiba 36A43 36" TV
Toshiba 32DF46 32" TV Logo
193 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
