Question about NEC VT47 Multimedia Projector
NEC VT660 Had large black oval on screen when on surrounded by yellow tinge, set against blu background Just replaced globe and still have same problem?
  • 157 Answers
From what you have described it sounds like a damaged internal lcd panel, can you post a photo anywhere and I can confirm?
Posted on Aug 31, 2009
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
I have a Sony projector and when I turn it on there is a cross cross pattern over the images. I can still watch movies but it has a yellow tinge and this cross pattern would this be globe problem?
If you are seeing a grid of lines on the screen that is in the older sets the convergence grid---exit is usually muting, enter. What if anything have you tried and what is model number of this TV? KP.......?
May 29, 2012 | Sony Televison & Video
The background projects as yellow instead of white. Everything has a yellow tinge to it.
It sounds like one of the polarisers has failed, on experience they cost £300 each to replace, and there are 3 of them. I recently bought an NEC NP115 for just over £200, very good spec for the cost. It maybe worth investing in a new one.
Hope I was helpful for you.
Aug 08, 2011 | Optoma EP771 DLP Projector
THE PICTURE IS NOT CLEAR A SHADOW BEHIND OBJECT, THE SCREEN IS OVAL
You most likely have a large magnetic source near the screen like a surround sound sub woofer or other speakers. also go into the tv's settings and have it auto adjust the convergence. should help
Aug 24, 2010 | RCA Televison & Video
I am getting a little flutter/flicker.. help..
the lamp is near the end of it's life or it's not getting sufficient voltage. check the lamp for bulges, black spots, fogging or flaking, and replace if necessary. otherwise, you have a ballast issue that will need to be repaired/replaced by nec. they won't sell individual parts.
Feb 02, 2010 | NEC VT660 Multimedia Projector
Dvd player plays with yellow tinge
If you are using a scart connection, check that it is plugged in fully & straight, also check for bent or missing pins.
Sounds like you have no green input.
Jun 06, 2008 | Televison & Video
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
ZENITH E44W46 LCD HDTV
Its your light engine failing. It can cause different colored "spots or ovals" to appear in the black background.
My Zenith ( now LG ) E44W46 LCD had the engine replaced after only 10 months, and now 3 years later it is failing again. There is a lawsuit against LG for using defective engine assemblies in this particular model.
After much searching I located this number, 800.243.0000 and called from work this past Monday at 8:15 a.m. central time. I was blown away to actually have someone pick up and direct me to a rep who reassured me that LG was aware and has set up a department to handle claims.
I was issued a case number and told that I will be contacted by a rep from this "department" and they would replace the set. With what I don't know yet but I will post back after I get thier final answer and the details.
Dec 02, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
NEC VT47 Multimedia Projector Logo
207 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
