Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
Need wireing diagram for a rci 2980 to tug8 mic
  • harryhoughto Feb 26, 2009
    I thank you for the code it worked great. Martian Utica,Ny TY
  • 39 Answers
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Posted on Feb 25, 2009
How to wire a D104 mike to a DAK IX Base Radio
Is the d104 a amplified tug8 (4 wire) or tug9 (6 wire)
or is it a non amplified mic?
Found this...hope it helps..........
Astatic (4 wire)
1- White
2- Shield
3- Black
4- Red
Astatic (6 wire)
1- White
2- Shield
3- Blue
4- Red
Black- N/C
Yellow- N/C
Dec 15, 2017 | Radio Communications
Rci 2990 won't keyup
If on all modes check the mic first to see if wired right or wires broken--this should have am-fm-lsb-usb---which works or do not work.
Apr 24, 2012 | Radio Communications
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
Jan 15, 2012 | Midland 1001Z 40-Channels Base CB Radio
RCI-2980 NO MODULATION
Microphones are the most handled object with a CB radio and this is where it is most likely to find the problems. Basically a Galaxy radio in a base station box, and 3 out of ten develop problems, mostly power supply problems.
I would suspect the mic first. Best way is to use a different mic and see if the problem goes away. Next try the radio on an external DC supply or battery. Let me know what happens from there..... poikaa@yahoo.com
Feb 19, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
Rci 2980 no modauliton on am/lsb/usb/fm.but good recived. and good output.on am.
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
Nov 26, 2009 | Radio Communications
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
404 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
