Question about Kenmore 23822 Top Load Washer
Washer will not agitate. the motoer is working fine but the agitator is not working. it is very loose as if it has came loose from it's base. i do not know how to access the inside of the washer to see what the problem is.
  • 5,911 Answers
If this is a Kenmore or Whirlpool model top loader, to access the washer interior, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
It may seem like a lot, but this process is much easier than you think. Once you have the interior exposed, inspect the motor coupling to make sure it is still intact:
1. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
2. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
3. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
A failed motor coupling is a common problem that causes a washing machine to fail to agitate. This part usually costs less than $20 to purchase. You can save a fortune in repair costs if you accomplish this on your own.
If the motor coupling is still intact, or if you have questions, please post back before rating the solution. Sometimes it requires additional feedback to get a full perspective of the symptoms you describe as there can be several causes of an agitator failure. In addition, you did not include a model number. If I am incorrect in my assessment of the washer make, please elaborate on that as well. I hope this helps you.
Posted on Feb 24, 2009
GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Feb 10, 2010 | GE Washing Machines
The washer quits spinning sometimes, mostly when
May have a basket drive going bad. Not a bad job but can be tedious to get to.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
RAS7233KQ0 fills but will not agitate
you probably have a loose or corroded wire to your agitate solenoid unplug the washer and, visually check this
Jun 09, 2009 | Roper RAX4233PQ Top Load Washer
Pop the top cover on the agitator.
Remove the screw inside.
Remove the agitator and inspect it for damage where it attaches to the transmission shaft.
Feb 24, 2009 | Kenmore 23822 Top Load Washer
Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
Feb 17, 2009 | Whirlpool WTW5800SW
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Kenmore 23822 Top Load Washer Logo
214 people viewed this question
Sal De
fordexpert
Robert Rankin
