Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
RCA ColorTrack 2000 - Picture getting small at bottom. Black line
The picture is closing in at the bottom.
Found adjustment in back of set for top adjust (Vertical Height).
Cannot find adjustment for bottom of picture. (Vertical Linear).
Is the adjustment inside set or could it be a capacitor going bad?
  • 718 Answers
Its the capacitors going bad. I believe you will see them as a pair.
Posted on Feb 24, 2009
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
Tip
Kitchen table, Screen (G2) voltage adjustment, Course 101
Well, those of you who have no idea why a Screen Voltage (technically known as G2) adjustment may interest you, here is a photo of a bad adjustment (too high).
You may also experience smeared colors… this is caused by a low adjustment. To correct this, we need to get the back off of the TV. It would be a good time to unplug it if you have not already done so. Next we locate the FBT (Fly-Back Transformer).
This is a 20” model and it has 2 knobs. Your FBT may vary, as some slim designs and some large tube models may have 3 knobs.
You will need to look closely at the knobs; they will be labeled “Focus” or “Screen”. On units with 3 knobs, there will be 2 focus knobs and 1 screen. For now, we will be working with at the Screen knob only.
With the adjustments identified, we are ready to plug the TV in (including your standard cable connection) and turn it on… BECARFUL!!! For the rest of this adjustment, we will be working inside of an electrically charged TV. We also need to normalize the picture, so go into your TV menu and adjust the Picture and Brightness settings to the middle or center.
If your TV normally displays a black screen when you do not have a signal connected, ex: Video input 1, then this will be the quickest and easiest setup for you to use. However, if you are not so lucky, you may need to bust through your DVD video collection and find a “between scenes” shot that you can pause on to give you as black of a picture as possible. Eliminate as much light in the room as you can (just remember, you still need to see what your doing)… we want a good view of the screen without the interference of ambient lighting.
Once you have your black screen all set, we are now ready to proceed to the adjustment. If you have lines on the screen, see (HIGH)… if you have color smear, see (LOW).
HIGH: If you have some lines in the picture with a washed out appearance, your Screen voltage is too high. You will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
LOW: If you have smeared colors in the picture that seem to trail of the edges, your Screen voltage is too low. You will need to turn the Screen knob on the FBT clockwise. Do this slowly, until you just see some lines zigzagging top to bottom on the screen. Now, you will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
The final set, switch the TV input over to your cable input and check out the picture. Take a good look at some bright scenes and dark scenes. Do they look ok? Adjust the Picture and Brightness in your menu… can you set the picture to your liking? If so, you are all set. If not, double check your work (remember to normalize the Picture and Brightness setting).
If you are unable to adjust the Screen voltage as described above, you may have a High Voltage problem with your TV. This will require a repair and is not covered by this tutorial.
If you are all set and the adjustment is good, we should have a quick look at the focus adjustment. Return the TV to your Black screen setup. Press the TV menu button to give you nice fixed display to focus. Adjust the focus knob(s) until you have the clearest picture. It’s important to balance the center of the picture with the corners of the picture. If the center is too sharp and the edges and corners are blurry, it is not a good adjustment. Do your best, you are the final judge of your work here.
Once you have finished the adjustments and verified the picture with your cable picture, you are ready to close it up and return the TV to normal service. Unplug the TV, replace the back cover… enjoy!
I hope this was helpful. If you benefit from this tutorial, please leave some feedback.
on Mar 21, 2010 | Televison & Video
The picture is oversized and the printing as in the stock ticker or in the sports scores can only be seen a little bit on the bottom. Can't find anyway to resize the picture.
Zenith sets, like most others now, are adjusted electronically through a service menu. You'll need your original remote control (or a Zenith-brand universal replacement with a MENU key) to access the menu. Press and hold the MENU button until the channel number and time display goes away, then press 9, 8 , 7, 6, ENTER. This puts you into service mode.
In service mode, CHANNEL UP and CHANNEL DOWN move through the different settings, and VOLUME UP and VOLUME DOWN change the values. Make sure you write down the original value of anything before you change it so you can put it back if necessary. One of the reasons the manufacturers hide the service menu is because the set can be damaged by incorrect settings to some of the parameters.
On some models, you can't get to all the parameters unless you change one called F MODE from 00 to 01. You might need to do this on yours.
The list of parameters varies by model and features. I haven't worked on a Zenith in a long time so I don't remember exactly what yours says, but you want to find two settings for V SIZE (vertical size) and V POS (vertical position). Adjust the size first by lowering the value until the top and bottom of the screen are black. Then adjust the position so the picture is centered (black strips close to equal size). Finally, increase the size until the picture fills the screen again. It's normal to adjust for a little overscan, meaning you push the top and bottom a little bit out of view. If you stop too soon, on some channels you might see flashing lines at the top of the picture.
When you're finished adjusting, turn the TV off to exit service mode. If you needed to change the F MODE setting, put it back to 00 first. Your picture should be properly sized after all this.
Mar 19, 2011 | Zenith SY2772DT TV
My projecters on my tv need to be adjusted. i was wondering how much that usually costs..
Adjust it your self you have a small Black box on it will be 6 controls 3on top for focus R/G/B and on Bottom are 3 screen drive controls R/G/B turn color off on menu then adjust screen drives as close as you can get to a Black and white picture, then go back to menu and turn color back on! with back off clean top of all 3 tube lenses.
Nov 13, 2009 | Televison & Video
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
Horizontial adjustment
your monitor has a problem with vertical sync. its time to bring your unit to a qualified service technician.
Jan 15, 2007 | RCA F36444 36" TV
Picture bows on top and bottom of picture......
Your problem is the convergence IC'S. They have STK ###-### the # are numbers. You can get parts at http://partstore.com. If your not a tech and an experimenter or a handi person Pease be aware of the hi voltage inside these sets. Also be aware your going to need to unsolder and resolder the ICs in and from the printed circuit board. Good Luck
Aug 11, 2006 | RCA P46924 46" Rear Projection Television
RCA F32649
i dont know this exact model, but i can advice you based on a slightly diffrent model. i hope the solution will be valid for your model as well: TV is digital controlled and have to be adjusted via service menu except the external focus and screen on back of (flyback) high voltage transformer. This is one you can try: Need plastic allen or plastic small flat blade screwdriver to fit these. Focus is top, bottom is the screen that set the overall brightness. Before adjusting, go in menu: press menu once, select picture quality, I think number 4, press 2 for "preset..", press 2 again to select normal. Back out by pressing zero repeatedly. It may ask you to save new settings, select yes. If screen is adjusted too bright, picture look lousy (washed out) the blacks will light up (becomes grey, or visible lines) this means you have actual fault that prevents you to get decent pix, that when it is time to take it in for repair.
Feb 11, 2006 | RCA F32649 32" TV
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
