Question about Frigidaire Dryers
Squeaky dryer put on new belt for a front loader fridgeidair dryer and now it squeaks , but I let it run and now it doesnt squeak as much but  could you shed some light
  • jagproductio Feb 24, 2009
    thanx couldnt understand the first part .Might be typing errors
    but very confirming
  • soccertb May 11, 2010
    how do i get into the area of the dryer to assess the problem,
    does the front of the dryer pop off?
  • 547 Answers
It the felt and the sliders you will need to change them next or drum will settle in and noise will stop thank you for useing fixya please rate me
Posted on Feb 24, 2009
  • albert getty
    albert getty Feb 25, 2009
    there was an s on it=its
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
Dryer is squeeking
Hi
The motor bearings may be worn. Remove the drum drive belt and then start the dryer. If it squeals with the belt off then the motor bearings are likely worn.
There is a small roller that tightens the drive belt for the drum. They can squeak. Remove the lower front panel and you should see the small roller near the motor and belt.
Another is the two larger rollers that support the drum. You will see this if you remove the front lower panel. Another is where the drum rides on the upper round part of the door/opening and it has a plastic guide that separates the metal drum from the metal door/opening. Over time this wears out and the two metal pieces will squeak.
Please check the bellow links to know detailed idea related to your query:-
http://www.ehow.com/how_5062711_fix-squeaky-dryer.html
http://www.mademan.com/mm/how-fix-clothes-dryer-squeaking.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeaky Kenmore Dryer
The idler rollera and belt tensioner have got bearings. One of them is failing.
Jul 07, 2009 | Dryers
Broke brand new belt
youve got a pully locking up,all except the crank pully should spin freely by hand if there good
May 25, 2009 | 1988 Oldsmobile Cutlass Supreme
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Dryers Logo
69 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
