Question about Kenmore 23822 Top Load Washer
Washer will not agitate.
The motor is working fine. The agitator inside the washer is very loose. seems like it has came loose from it's base. How can I access the inside to check?
  • Anonymous Mar 16, 2014
    agitator seems loose inside drum
  • Kenmore Master
  • 3,361 Answers
Pop the top cover on the agitator.
Remove the screw inside.
Remove the agitator and inspect it for damage where it attaches to the transmission shaft.
Posted on Feb 25, 2009
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Will not agitate or spin. Have replaced the belt (was worn) but still wont. Fills fine. When I first put the new belt on I ran it empty (stopped it when it started agitating, moved it to sping, stopped...
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
Feb 23, 2011 | Maytag HAV3460AWW Top Load Washer
Agitator not moving--seems loose
This washer has what we call a bionic agitator and this agitator has a 2 parts:
it has a base and a top section.
IF the BASE IS NOT WORKING AT ALL, please have the transimssion checked and also check the coupling.
IF the BASE is working and the top is NOT
THEN replace the 4 plastic AGITATOR DOGS that are in the agitator.
Remove the CAP from the agitator...remove any plastic cap.
Get a socket wrench and get the socket that removes the bolt.
remove bolt...
PULL the agitator from the base and separate the top from the bottom.
Take the top and turn it upside down to remove the platic interior part that holds these 4 dogs. REMOVE the old dos and replace with new and do a reverse engineeriong putting agitator back.
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer agitator won't agitate
Look at the center. can you pull the agitator up and out of the tub? You can try it with the motor running but don't grab it too snugly. Try and push it up and down while running. If it seems to try and move there used to be a rubber spindle on the trans shaft under the agitator that would become separated. I don't know if yours has one or not but the agitators were a bugger to remove usually because of the corrosion that happens. A special tool that was an air bladder used to fit under the agitator and you'd blow it up like and inner tube and pop it off. If you get the agitator off you try to get it to agitate and if you cant stop it by hand your at the problem either you'll see it obviously or it will come apart inside the agitator.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Feb 01, 2009 | GE Profile WPRE6100G Top Load Washer
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Won't spin or agitate
Sounds like a burning out motor to me...
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
Kenmore 23822 Top Load Washer Logo
134 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
