Question about Audiovox CDM-8915 Snapper Cellular Phone
Phone will not turn on (boot) fully - powers on over and over
Displays restoring user data 1,2, or 3 before recylcling
virgin mobile is provider
have data cable and multiple pst/cdma softs and saved info qcm files
possible to do a hard reset?
  • ftlion Feb 24, 2009
    nope - have six different charged batteries
    methinks is broken filesystem - need way to reload original firm/software or somehow get it to discard broken data...
Maybe it needs to be charged more
Posted on Feb 24, 2009
I need forget security code
hi Sunil kumar
try this one
note all data will be deleted
*#7780# FOR SOFT-RESET- does not delete user info such as contacts, sms, etc
How to do it:
- at Standby Screen type-in => *#7780#
It will ask for "Restore all phone settings-phone'll restart...."
Then it asks for security code enter factory default => 12345
*#7370# FOR HARD-RESET- deletes all user info
How to do it:
- at Standby Screen type-in => *#7370#
FOR FLASHING- TOTAL RESTORE: (Do this if your phone does not boot up) - you can say this one gives you the "New" OS, and of course deletes all user info
How to do it:
1) Remove the battery, and then wait for about 20 min or so before putting it back
2) Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
3) switch ON the phone.
4) Do not let go the three keys until you see the WELCOME screen displayed and just let it complete the boot process
Jul 07, 2014 | Nokia E63 Cell Phone
What is a problem when My Phone does not displaying the keypads when im trying to type sms or mms
Software of your phone is corrupted. easiest way out is to factory restore your phone....BUT THIS WILL EREASE ALLL USER DATA INCLUDING PHONE BOOK ENTRIES STORED IN THE PHONE MEMORY....However sim and memory card data will not be effected.........to do this...go to settings and select restore factory settings/full factory restore...ur phone will ask for security code....for code refer user manual..or enter code that u have previously changed.......if this fails then switch off phone,....remove battery....reinsert battery....press volume up,and Power button for about 15 seconds.........till boot mode appears and u get some text written on screen....using volume up key scroll thru the text and select erase all user data/restore....now press power button for about 2-3 seconds......process begins........restart phone.......this should solve the problem...........but if still problem persists then u will have to visit a service person who will flash ur set using special tool loke...volcano box.
May 20, 2014 | HTC Hero Smartphone
I have a virgin mobile cell phone forgot locked pattern how to by pass it
  1. Press and hold the POWER key and both volume keys
  2. Continue to hold all 3 keys until an exclamation point and a little green android robot appear
  3. Press the HOME key to display the menu
  4. Navigate using the volume keys
  5. Select Wipe data/factory reset
  6. Use the BACK key to select
  7. Scroll down to Yes delete all user data
  8. Use the BACK key to select
  9. Select reboot system now
Apr 14, 2014 | Samsung Cell Phones
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
My virgin mobile is stuck on the main screen
Hey,
Turn off the phone. While the phone is off
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note: You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note: The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
Mar 31, 2013 | Virgin Mobile PCD Venture No-Contract...
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
    Note
    Note
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
When i switch on my phone, on the display it shows contact service what is the solution
Sounds like the phone is telling you there is a problem, with it or your service provider. Time to do as the message suggests and call your cellular company, to see what the message could mean.1. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for ALL operations listed here is 12345
2. *#7370# - Reformat your phone (out of the box, tho keep in mind that most newer nokia phones at least n series, e series and s60 based phones have udp - user data preservation so not ALL data may be lost. still it is a good idea to always do a back up of your stuff.)
3. This you perform as a last resort. Nothing else is working.If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons
Feb 24, 2012 | Nokia 6303 Classic Tri-Band Cell Phone
Helio Ocean. Stopped sending pic messages. Tries, then pops up "Couldn't send message. Try again?" Repeatedly.
hi there,
I was having the same issue and here is what I learned:
I contacted technical support through Helio's carrier (Virgin Mobile) and here is what I learned: Dear Jennifer , Thank you for contacting Helio by Virgin Mobile. We are sorry that you are having issues sending and receiving picture messages on your phone. We are having some system updates and that is causing you not to be able to do some of the data services on your phone. We expect the issue to be resolved in the next 24-48 hours. If you need further assistance, please do not hesitate to call us at 1-888-88-HELIO 1-888-88-HELIO 1-888-88-HELIO 1-888-88-HELIO. You can reach us Monday through Friday 6am-9pm PST and Saturday and Sunday from 6am-8pm PST. Regards, Khalidine V Helio By Virgin Mobile Customer Care www.helio.com
Jan 03, 2010 | Helio Ocean Cellular Phone
Virgin mobile Shuttle keeps turning off and on!
i took the battery out of the cell phone and every five seconds it keeps turning off,then back on..how do i make it stop, and how can i make it stay on?
Sep 29, 2009 | Cell Phones
My virgin mobile shuttle keeps turning on and off
Sometimes when mine does that and I remove the battery there is a small piece of dog hair or schmutz on the copper part of the battery.
Apr 04, 2009 | Cell Phones
Audiovox CDM-8915 Snapper Cellular Phone Logo
118 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
