Question about Linksys Wireless-G WRTP54G Router
WRTP54G Ethernet problems
I'm hoping someone has seen this before. I've had this router for 3 years and just recently i've been having the ethernet port dopping. No problems with the VoIP or wireless just the wired connections. I've tried different ports to see if the problem follows and it does. All 4 ports drop for 3 seconds then re-establish. This has been going on for the past few weeks but i haven't been concerned because it wasn't so bad then.. Just in the last 2 days, the 4 ports have been dead. I reboot the router and they work for a few hours, then they're out. No link lights on the 4 ports. Any ideas and thanks for your help and suggestions!
  • luke65 Mar 16, 2009
    I had the same problem for months. I hooked up a DLINK I-524 to my cable modem and hooked the WRTP54G to that. The phone ports still worked on the WRTP54G, so I just used my DLINK for the wired ports and wireless connection. Aftr about 6 months of that working without a hitch, I was geting the error, "vonage device cannot contact the vonage network" when talking on my phone. It would work for a few minutes and then cut off with this message. Today I was on the phone for 2 hours and it was fine. Then I tried to make a call again later and got the recording. I called Vonage and spoke to tech support in the phillipines. They are sending me a DLINK Vonage router for free with the stipulation that I must return the WRTP54G. My other choice was buy another WRTP54G at some retail store and vonage would send me $40. The WRTP54G is selling online for $100 and up. When I bought this I thought it was under $100 and with the rebate from vonage it was practically free. So I took the free DLINK deal. That is also a $100 router. Why take $40 rebate and pay the extra $60 plus.
  • 496 Answers
It almost sounds like a failing pc board in the router just old and dying could be firmware try updating , reboot the router before the firmware update you dont want it going out during that
Posted on Oct 01, 2009
I had a similar problem with the WRTP54G, after working great for almost 3 years the ethernet port started to fail intermitent and getting worst week after week. This is normally sign of hardware issue, so I opened my router and replace the 2 capacitors of the main power supply (1000uF x 16V), they were quite fat, indicating a leakage occured. After doing this, the ethernet ports came back to life perfectly!I hope this solution can help someone around the globe, as this router is very good and with less than U$0,50 you can fix it.Marcelo macedo.
Posted on Feb 07, 2012
Having problems with 2wire router that keeps dropping the internet. All light are on except ethernet, does this mean the router is no good. Recently replaced the power cord which helped for awhile.
how do you connect to your router? If there's no ethernet cable plug in on the router, the Ethernet light on your router is suppose to be off. Also try to move your router 2-3 ft. away from any electrical devices like wireless phone, printer etc. because of electromagnetic interference. It may help your wireless connection to be stable and faster.
Jan 09, 2011 | 2wire (2701HG-B) Wireless Router
I've been playing online with my ps3 for years now since it first came out. i connect with the ethernet cable my system came with and it has always worked but last week i pluged it in like usual in my...
hello have you tryed another ethernet cable also turn the power off at the router take the lead out at the back of the router there should be reset button hold this in for 15 seconds re plug in everythink in hopeful it should work good luck
shaun
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
Apr 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
WRTP54G not routing
turn the power off for 5 minutes then try.
if still pro let meknow.
Jan 05, 2009 | Linksys Wireless-G WRTP54G Router
Router
Yea, if you have your initial run CD, use that but here is how you do it.
MODEM-ROUTER-COMPUTER
I
Other wireless devices.
You plug the ethernet cable going from the modem into the plug on the router labeled internet. Then give it a cable from ethernet slot 1 to the computer. You should be good 2 go.
May 23, 2008 | Linksys Wireless-G Broadband Router
Wireless router needing ethernet connection?
Hi ABVT66 - Didn't your router come with two short cables? It should have. One is the cable that hooks up the modem to your router and the other is the cat5 (ethernet) cable that connects your router to your pc. Let me know if you have these cables. Also, if you check your device manager on your pc, click on the + next to network adapters and it will tell you your network adapter. DON'T RATE THIS 'TIL WE'RE DONE. Thanks.
Jeff
May 22, 2008 | Computers & Internet
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRTP54G Router Logo
488 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
