Question about Kenmore Elite 45986 Front Load Washer
Flashing code My washer keeps giving a code F H in the middle of the cycle.
  • jacarter Feb 25, 2009
    Hi, I have the HE3T washer and half way through the normal cycle, the washer will stop and the code F 11 will flash, the door won't unlock then the code DL will appear. Can someone please help
  • 5,911 Answers
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more involved error codes to try to resolve because there are so many causes. I suggest you start with the simple things first. Make sure the water inlet hoses are unclogged and water flows freely through them. You can determine this by turning off the water and removing each hose from the back of the washer. Place them in a bucket or position the washer where you can place them inside the wash tub and turn the water back on. Both hoses should have free unobstructed water flow. It is common for the sediment screens at the end of the hoses to become clogged if you live in an area the uses well water, or if you have hard water.
Next, Make sure you don't have a siphoning problem. This is causes by placing the drain hose too far down in the standpipe. This creates a vacuum and the washer constantly drains as it tries to fill. If you pull up on the drain hose and hear a sucking noise, you have the drain line positioned too far in the standpipe. You need to keep an air gap in order to allow proper drainage.
Then, check the drain pump for obstructions. There is a clean out reservoir that you can remove the access the pump interior. Use the instructions I provide to perform these steps.
These are the simple items that you can easily rule out, first. Follow the remaining tips I provided you and if you still have questions, let me know before rating the solution. I hope this helps you.
Posted on Feb 24, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Dr is flashing. The error code is E41. How do I correct the error code. Door is closed. Started flashing in the middle of cycle.
Hello, welcome to FixYa. I understand you have a Frigidaire washer with an error code E41, correct ? Can you reply and include the complete model number ? This will let me speak specifically about your washer instead of generalizing...which can be fine, but specifics are always better. I'll watch for your reply and go from there. Thank you. Regards, Macmarkus :)
Sep 17, 2011 | Frigidaire ATF6000ES Front Load Washer
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Cycle stops - F error code
I am having the same problem with the "F" flashing and a beep but no numbers. The manual only says to hit the stop button then the start again. It doesn't give you a problem. It then says if this does not work to call a repair man. Mine is only two years old and we loved. I have never had any problem with it but every review I have read says differently and they seem to happen around the two year mark. It seems they have a malfunction timer that goes off at the two year mark. If you find a solution please post again.
Aug 06, 2008 | Washing Machines
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Kenmore Elite 45986 Front Load Washer Logo
53 people viewed this question
Sal De
fordexpert
Robert Rankin
