Question about GE Spectra JBP78 Electric Kitchen Range
It looks like the glass top is burned around the cooking areas. Is this cleanable from underneath the glass unit?
    Scholar:
  • 145 Answers
No, use DeBruce Polish on top surface go to debrucepolish.com
Posted on Feb 24, 2009
I have a Maytag glass top stove are the burns suppose to turn off and on while I am cooking on it or just stay on all the time? Please someone help me with this.
i used a glass top cooker just recently and I noticed the same effect
the cooking process was not interrupted so I would say that it is part of the energy saving characteristic of the glass top cooker where once the set thermostat setting is reached, the burner is switched off until the thermostat turns it back on again
the glass top cookers are advertised as more energy efficient than the coils and solid plate so discuss this with a retailer or service agent to ensure that there is no faults in the unit
Oct 26, 2016 | Maytag Kitchen Ranges
Tip
Replacing a Glass Cook Top
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
  1. Unplug the cook top and leave the elements in place.
  2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
  3. Remove the surface element assembly leaving all the elements wired together.
  4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
  5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
  1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
  2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
  3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
  4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
  5. Lower the new cook top into place and secure with screws.
    Good luck and I hope this helps.
on Mar 02, 2010 | Kitchen Ranges
Why are my rolls not cooking on the bottom but fine on the top and my element is working fine
My guess is this is an electric range. If I am right then it has 2 elements--one on top and one on the bottom. Plus you stated it has convection cooking. Sounds like the bottom element in not working right so all you are cooking with is the top element. In convection cooking the fan circulates the air for even cooking.and sometimes has its own element around the fan. Look closely at the bottom element for any burned out or melted areas that might show. Sometimes they just burn out with no outward signs.
Feb 22, 2015 | Kitchen Ranges
Spectra range. Both large burners diagonal across from each other have stopped working. Is this fixable. Other burners OK.
yes it is is this glass top type ? very easy to work on and get parts for , first thing unplug unit from walll, there are two screws near the front of the oven.to the left and to the right of the oven.near the top front . once you remove the screws lift the top up and support it with something look at all the wires and you will see one that has been burned , the only wire you can use inside of this area is what they call glass wire , so it will take the heat . I am almost positive this is just a burned wire , replace the burned wire with glass wire and you should be all set, keeping in mind move the wires away from the burners this time so it wont happen again
Jul 26, 2011 | General Electric Kitchen Ranges
I burned my glass lid. Left the gas burner on and
It depends on the age of your range. Is this the glass cook-top that is burned or the glass door of the oven? Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday fr all your appliance repairs, parts & accessories.
We look forward to working with you and wish you Happy New Year! Thanks, Ella
Jan 09, 2010 | Kitchen Ranges
GE profile top
Yes, the glass cook top can be replaced. These counter top inserts are actually fairly simple to repair, but the entire assembly usually has to be uninstalled to accomodate removing the glass top and installing a new one. You will need to provide a model number by opening the cabinet underneath the cook top and looking for a nameplate in order for me to assist you further in determing a part number, cost and how to disassemble.
Aug 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
I have a Kenmore electric range oven Model # 79095201103 that has a glass top. The top cracked and I ordered a new glass top for it. What steps do I need to do to replace the top. Is it complicated???
Here ya go...
Apr 06, 2008 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
