Question about Video Game Consoles & Games
X-box wont power off
After I remove the game from playing the X-box wont power off it just reboots and the tray stays out. I have to unplug the power cord to shut it off.
  • libraman9280 Mar 12, 2009
    There's nothing wrong with the cord. I can play for a minute and it happens
All u have to do is take the cord out and let it sit for a while
Posted on Feb 24, 2009
Laptop shut down and wont power up
Unplug, remove battery, check for dust in fans and vents, plug in, try to reboot. If it powers up, open Control Panel, Power Options Power , set to High Performance, open Advanced Power settings, set Sleep and Hibernate to Never, Adjust other Advanced settings to your preference. Has it been pulled by the cord? If you have a multimeter check for DC volts at the AC jack plug, that plugs into the laptop. Is the Transformer (brick on the cord) getting warm when plug in? Does the battery charge LED light? Try another cord with the EXACT same power specs.
Jan 23, 2013 | ASUS G73SW3DE Republic of Gamers 173Inch...
On xbox 360. my gears 3 disc freezes the console. when rebooted it says the disc is unreadable. i'm on my 3rd disc. when i remove the hard drive, i can play gears 3 but cant save . i have played gears...
Hello
Delete any saved game files from your x box hard drive.Unplug x box for 5 min.
Plug back in and power up.
Try game again.
Chances are files have become corrupt.Also delete any files from GOW 1 and 2.
Oct 19, 2011 | Microsoft Xbox 360 Console
My xbox 360 wont play my game, it says reading te disk then it says open console every time and it just started doing it.
i have had this problem before and i fixed by unplugging and replugging power cord (make sure 360 is off before you do that) then opening and closing tray 4 or 5 times
Jan 15, 2011 | Microsoft Xbox 360 Console
My door will not stay shut to play a game what is wrong.my ps2 door was not opening so we thought we fixed it but now it wont stay shut . all lights are on just wont stay shut to even read/play any games...
the tray doesnt stay in. does your ps2 sit on its side where the tray is sideways, or is it straight up? i think you should try rotating it to a point where it should stay shut.
Feb 11, 2010 | Sony PlayStation 2 (PS2) Console
Disc tray wont stay shut,just reopens after a couple of seconds.only 14 months old.
Check the faceplate on the front of your drive tray. It might not be on right. I would take it off and try it then to eliminate it as the problem. It's very easy and won't affect your warranty. Hold the power cord and open the tray. As soon as the tray opens, unplug the console. I recommend unplugging the back of the Xbox rather than the outlet. Then gently pull out on the plate and lift up. It should pop right off. Don't force it. Then, with it off, try the drive again. If that doesn't work, it's jammed inside or the button is sticking.
Nov 16, 2009 | Microsoft Xbox 360 Console
Xbox 360 tray wont shut
u can give the tray a little push and see if it moves in, i know someone else who had the same problem, if you cant play games the laser reader may have died on you
Dec 26, 2008 | Microsoft Xbox 360 Console
Disc Tray wont stay shut
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
Xbox Support: 1-800-4MY-XBOX
Jun 22, 2008 | Microsoft Xbox 360 Console
X box 360
Orange means = stand by
Green= its ON
Red= theres a problem (usually power supply overheating)
There could be many reasons as to why your console wont switch on such as broken power switch, faulty / damaged power cord / supply unit, or over heating has damaged the console.
If possible try using teh power cord in another xbox 360 console to eliminate the cable being the problem.
If the problem still exsists all that you can really do from there is send it to the xbox repair center.
You should be able to get it fixed free of charge.
if you have a game or dvd in there you cant get out unplug teh console and remove the face plate. depending on the dvd drive manufacture in your xbox you may / maynot be able to see some small black cogs at teh front of the dvd drive inside the actuall dvd drive unit. spin these with a small techinical screwdriver and the the tray will start to slide out with each spin.
Not very technical or approved but does the job.
hope this helps
Anthony Kinson
Apr 20, 2008 | Microsoft Xbox 360 Console
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
My xbox wont stay shut
push it in until it closes .i know it sounds crazy but it worked for my ps2. i dont know about xbox though.
Nov 13, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
