Question about Tappan TGF320 Gas Kitchen Range
Tappan 30" gas range oven door will not close
Last week the door on our 30"' Tappan gas range (no frills) would not close the last inch or so, so the oven has not been used.
I found nothing obviously jammed, tried WD 40- no luck.
Have started removing LH (when facing stove) panel removal, but don't see anything much yet as to how to further disassemble.
Nothing seems fractured, etc.
What is the usual disassembly procedure further? Have not removed door itself as it seems that would just give me a separate door!
Harold
  • Anonymous Mar 02, 2009
    Tappan Gas Range and oven. Door won't close all the way. There is no apparent damage to the door or oven. The hinges at the bottom of the door seem to be operating properly. The door seems to be aligned properly.
    I suspect the problem to be in the door itself. I am reluctant to disassemble the door without knowing what I am getting into.
    Suggestions? Resolutions?
2 Suggested Answers
SOURCE: oven door
replaced oven igniter without removing oven door
Posted on Jan 10, 2009
marka19
  • 1430 Answers
SOURCE: Tappan range. Model #30-3991-00/01, Serial
The main control ERC has failed. The timer and all functions are controlled by one main control board. Here is a video that should help http://appliancehelponline.com/ovenerc.html
Posted on Sep 13, 2010
Tappan gas range oven door hinge is binding
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
My oven door will not close all the way.. Help
In order for you to give me the solution I have to pay for it.... You are asking me to give you my soultion free?????
Dec 13, 2009 | Tappan TGF657 Gas Kitchen Range
Oven door will not close all the way. 6" gap at the top. No problems until last use and now won't close. Any hints on how to proceed would be appreciated. Thank you!
Most oven doors are held in place by two hinges at the bottom. Usually these hinges are not attached but hook into the oven.
Sounds like you need to readjust one or both of the hinges.
Usually can be done by pulling up on the door and pushing the bottom of the door in.
Write back if you have more problems.
Dec 02, 2009 | Tappan TGF320 Gas Kitchen Range
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Thank you for using FixYa.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Oven door
Jan 08, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
202 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
meztang
meztang
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
