Question about Plantronics Discovery 925 Bluetooth Headset
925 Plantronics will not pair with cell phone.
Worked fine for 2 weeks, now shows both blue and red flashing.
  • 32 Answers
You are holding down the main button too long.  When it flashes blue and red it is now in pairing mode.  To turn on the headset hold down the main button until you see the blue light come on, then let go.  If you hold it any longer this is when it goes into pairing mode.
Posted on May 22, 2009
To force start the pair press the + volume and the talk button in the middle simultaneously.
Finally found the solution after 20 minutes of searching, and I was about to tell my boss his bluetooth didnt work anymore
google <3
Posted on Jul 23, 2009
How do i put it into pairing mode?
Hi!
To put your Plantronics headset into pairing mode: with headset OFF please press and hold the CALL CONTROL button until the light on the headset begins to flash red and blue.
When the other device (e.g. mobile phone) ask for entering a passcode, please enter 0000.
Please let me know if it helped.
Regards,
Aug 20, 2011 | Plantronics Discovery 925 Bluetooth...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
    Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
    Plantronics Discovery Pairing Instructions
    Good luck from Headsets Direct!
    Apr 27, 2010 | Plantronics Explorer 330 Headset
    Headset does not flash red/blue so I can pair it with my phone
    To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
    May 09, 2009 | Plantronics Discovery 925 Bluetooth...
    Cannot get my 925 to work on my computer as an audio unit for use with Skype. Cannot find a driver that will work on VISTA 32bit
    Have you placed the 925 into discovery mode?  It will be flashing red and blue rapidly if you did.  Here's how to do it: Turn the headset off by holding the main button down until a red light comes on Turn it back on by holding that same button and keep holding it after you see the blue light come on.  Eventually it will start flashing red and blue.  This is now in pairing mode.  Set your computer (if it is bluetooth enabled) to find all bluetooth devices.  It should be listed as Plantronics 9xx.  If you need a passcode it's 0000.
    Apr 20, 2009 | Plantronics Discovery 925 Bluetooth...
    Switching on discovery 925
    Switch the bluetooth function on your phone, search for devices and then pair with your headset once it finds it. Allow it to connect without confirmation and leave your bluetooth switched on on your phone. Everytime you turn on your headset it should connect automatically.
    Apr 10, 2009 | Plantronics Discovery 925 Bluetooth...
    I need to know how to pair my plantronics discovery 925 - I have no user instructions
    set your phone to discovery mode. press and hold the button inside of the diamond until it flashes blue and red. once you do that, your phone should see it. Pair it to your phone by putting in code. 0000.
    Happy Calling :)
    Dec 19, 2008 | Plantronics Discovery 925 Bluetooth...
    Plantronics explorer 330
    I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
    1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
    2) Make sure your phone's bluetooth is on and on discover mode.
    3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
    4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
    P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
    Mar 15, 2008 | Plantronics Explorer 330 Headset
    Headset setup
    http://www.plantronics.com/north_america/en_US/products/cat1150057/cat1150057/prod5560012?prodfind=true&mftr=MOTOROLA Go to this website, and scroll down to Interactive Bluetooth Pairing Guide. (Plantronics 330 - V555 doesn't show 320 and instructions will be similiar). Click on Interactive Bluetooth Pairing Guide and a tutorial will walk you through the steps. Have headset and phone together when you do this and both must be charged. Hope this was helpful. Pam
    Jun 11, 2007 | Plantronics Explorer 320 Wireless Headset
    Plantronics Discovery 925 Bluetooth Headset Logo
    1,241 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
