Question about HP J3680 Officejet All In One Printer
Hi, Please help me. My 14 year old son undertook to set up my new fax machine this morning. In his haste he accidently palced the wrong ink cartridge in the right side cartridge holder. Then he persevered and forced the cartridge intended for the right side into the left cartridge holder. I am unable to get them out. Can anyone tell me what to do? Much appreciated, Markus
  • 1 more comment
  • m_dupreez Feb 25, 2009
    I have been pulling it. It does not want to release?
    wher must i insert the screwdriver. the cartidges is not releasing at all?
    the cartridges is not releasing at all?
    President:
  • 1,952 Answers
Http://www.fixyourownprinter.com/forums/inkjet/21041
http://www.fixyourownprinter.com/specials/parts/belts/S313
Just scroll up, the link for belts and installation instructions is right there..
1. Click on the "Start" button.
2. Click on "Settings" and then, to the right of this, click on "Control Panel".
3. In "Control Panel", click on "Printers and Faxes".
4. Here you should find an icon identified as "HP DeskJet 722C".
Right click on this, which will open a drop down menu. At the bottom, click on "Properties".
5. Click on the "Services" tab.
6. Click on the box identified "Align the print cartridges." This should get you to the two familiar screens for aligning the cartridges.
Posted on Feb 25, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Suggestion:
  • power on the printer;
  • soon as the carriage moves out of rest/lock position, unplug from the mains;
  • the carriage should have moved to an almost center position ;
  • insert a flat bladed screwdriver in between the far end of the ink cartridge and the casing/cartridge holder;
  • the screwdriver should not be inserted that deep, there are electrodes in that area (lower) that could get damaged;
  • gently twist the screwdriver;
  • the idea is to dislodged the top portion from the rear;
  • the cartridge installs-and removed from an angled/inclined position.
A friendly reminder, the possibility of further damage is always there, care and caution should be exercised.
Good luck and thank you for using FixYa.
  • 547 Answers
You need to push back and up then out. thank you for useing fixya please rate me
  • albert getty
    albert getty Feb 25, 2009
    as the cartaridge gos in back to front it needs to come out front to back push in and up then lift out
  • albert getty
    holding tray with other hand
    Sergeant:
  • 250 Answers
The cartridges are are very firmly got stuck internaasly in the socket just tap the cartridges slowly to make them loose.if you find id risky then do not try because if by chance the socket where the cartridges are installed breaks down.it will cost you near to $ 25 for only jusr replacement socket.taking it to the local repair center will not cost you more then $5 for removing this.as its just a job of 1 minute not more then that.but if you feel it will crack do not force.
Posted on Feb 24, 2009
  • HP Master
  • 13,433 Answers
Hey,
just follow the instructions pointed out on the user manual that came with the printer to first get the cartridges to come to the center so you can get them out, as they where forced in to the wrong slots, it will have to be 'forced' out from them aswell, hopefully this wont break the printer.
you may attempt to help the cartridges with a flat screwdriver.
ones they are out inspect them for any damage and insert them in to the right slots and see if it functions.
    Scholar:
  • 165 Answers
Do it carefully.just pull the cartridges slowly towards yoursely.
be carefull.
Receive a fax
hi , please following the step , fax ring the time you take hand set & press the start button & place the hand set
Mar 24, 2014 | HP 2140 Plain Paper Fax/copier W/ink brand...
Fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Jun 18, 2008 | HP 1010 Plain Paper Inkjet Fax
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
Warning:
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
I hav installaed new cartridges but the is offline and i cant
I have a Printer problem - "Ink System Failure" - Ink System has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc18a001". This is what the glass on the left side says. I don't use faxes, so don't care of that. My Son installed an ink system, which of course is a lot cheaper to use, quite some time ago which has been working super. Yesterday the "Ink System Failure" sign came on and my Son was here this morning, but couldn't figure out what is wrong with the printer. I am in Heidelberg, Germany and buy my equipment in the AAFES PX. There is no HP technical service available to us Military people. The Germans won't work on American goods. Is there any hope for me? Thank you.
Phil Gatchell
P.S. I am the Adjutant/Finance Officer of an American Legion Post in Heidelberg and use my color printer extensively. So I am in a bind.
Jul 17, 2009 | HP DeskJet F4280 All In One Printer InkJet
Faxing a high volume of responses on Brother MFC-8220
Hi Gina,
It sounds like the MEMORY function is not set to ON.
Is there a memory button on the control panel?
Oct 16, 2008 | Brother Office Equipment & Supplies
No dial tone
Problem solved - new cable bought which seems to have sorted the problem.
Sep 26, 2008 | Brother FAX 930 All-In-One Thermal Printer
FAXES STUCK IN MEMORY
Unplug power cord and re plug in.
Jul 30, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
We can send fax but can't receive...new fax line, old fax machine...panasonic kx-fc195
hi zebaron,
check your ink film maybe its empty, check the receiving mode if its on automatic mode, if its on manual mode you have to press the start button to start receiving fax.
hope this help....
Jul 24, 2008 | Panasonic Office Equipment & Supplies
New crt
Hi there. This message on a Canon fax means that the ink is low. CRT stands for cartridge. Replace the FINE cartridge, as ink is low.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jul 02, 2008 | Canon FAX-JX200
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
HP J3680 Officejet All In One Printer Logo
19 people viewed this question
Ben Johnson
