Question about Gigabyte GA-8IG Motherboard
Computer won't read my camera memory card...
I'm getting a code 10 error,this device cannot start on my SD memory card. I have down loaded the latest video drivers to no avail. I've been trying to figure out how to assign IRQ to VGA, but I'm not having any luck.
  • 6 more comments
  • Anonymous Feb 24, 2009
    windows xp is the OS. SanDisk is the memory card. The computer will read the card when plugged into my cannon camera via a USB cable. I get (device cannot start . code 10) when looking at the device manager.
  • davisres1 Feb 26, 2009
    I goggled this and read that I should assign IRQ to VGA in the BIOS setup.
    I read that I should assign the IRQ to the VGA in the BIOS setup, but was having trouble doing that. Is this wrong?
  • davisres1 Feb 28, 2009
    I tried your serial bus uninstallation, but that didn't work either. I get the same code 10 error. The memory card works perfectly in my other computers.
  • davisres1 Mar 02, 2009
    Nobody knows...... : (
  • davisres1 Apr 02, 2009
    someone told me, " maybe the memory reader isn't working because I installed service pack 3". If I uninstall it and go back to service pack 2 maybe it will work. What do you think?
  • davisres1 Apr 22, 2009
    I'm trying to compress and e-mail a short video, but I'm having trouble setting up an outlook express account. How do i know if my e-mail server is HTTP, POP3, or IMAP, and what the incoming mail server is???
  • bstewart806 May 11, 2010
    The video drivers are not the problem in this case. If your computer is booting and you have access to windows in a normal monitor the video drivers are working fine.
    What I am getting from the question is that the computer will not read the SD memory card when connected to the computer without the camera present. In the case that the camera is present and connected via a USB cable, you will need to uninstall your camera drivers and reinstall using latest drivers from manufacturers website.
    What model camera and SD card are you using? What OS (Windows XP, Vista, 2000)?
  • 4 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, you want to rule out any problems with the device itself. A good way to do this is to blame the USB device into a different computer to see if it works there, if it doesn’t work in a different computer and the problem is with the device itself. USB devices, although very handy and portable can fail just like any other device
However, if the USB device works in another computer system than the problem lies with the configuration of the computer where the device did not work
Follow the steps below to troubleshoot this scenario and make your USB device work
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Posted on Feb 26, 2009
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
Sep 23, 2012 | Canon PowerShot A410 Digital Camera
My computer quit reading the card or the camera, so I can't get pictures from the camera onto my computer
Try removing theSD memory card from your camera and inserting the SD memory card into an USBmemory card reader then connect the USB card reader into the USB port of aworking computer. The computer will see this USB card reader and SD memory cardas an external storage device. You can open the camera photo folder and copythe photos to your computer.
Apr 13, 2012 | Nikon Coolpix S4000 Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
C190-caot be read with 2 differnd SD 4GB cards. Is
Hi sir
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 15, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
Multi-use SanDisk 2GB SD Card
Windows cannot use this hardware device because it has been prepared for safe removal, but it has not been removed from the computer. (Code 47)Recommended resolutions
Here are some things that you can try to resolve this problem.
Reconnect the device
This error code occurs only if you used the Safe Removal application to prepare the device for removal, or pressed a physical eject button.
Reconnect the device to your computer
Disconnect this device from the computer, and then connect it again.
Restart your computer
Make sure that the device is connected correctly to your computer, and then restart your computer. Click Start, click Shut Down, and then select Restart in the Shut Down Windows dialog box to restart the computer.
Dec 28, 2008 | SanDisk 2GB microSD Memory Card
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Gigabyte GA-8IG Motherboard Logo
2,578 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
